Old 06-27-2021, 02:21 PM   #21
callmedave's Avatar
2013 28' Flying Cloud
Cohasset , Massachusetts
Images: 14
RA kit
Originally Posted by NO NOIZE View Post
Perfect!!
Dave
Wallace: 2013 GMC Sierra 2500 D-Max
Gromit: 2013 Flying Cloud 28
_______________________________
callmedave is offline   Reply With Quote
Old 06-27-2021, 03:31 PM   #22
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
This thing has worked great for me in the weird tight spaces of the Airstream.
2019 Ford Expedition Platinum
Old 06-27-2021, 05:45 PM   #23
kbmwrs's Avatar
2016 25' International
Morgan Hill , California
I'll probably get the Dewalt 90 drill. No rush. AS on side of the house and we're living in it for the next few months. Having our house worked on.
Thanks guys.
kbmwrs is offline   Reply With Quote
Old 06-27-2021, 07:02 PM   #24
Sag Harbor , New York
Thumbs up
Thanks for the update.
Peter
Old 07-04-2021, 10:44 AM   #25
kbmwrs's Avatar
Update.
I bought the DeWalt 90 drill attachment. Worked great. I added another screw to the hinge. There are 3.....thought there was only 2. There is one directly in the middle hidden by the hinge arm itself.
I also fixed the latch for the curved door. This is the ball bearing clasp. Mine for some reason spat the ball out. And the spring went missing.
I went to the hardware store and got a right sized ball bearing and a small spring...although too long. I cut the spring and for a total of $1.12 I fixed the latch.
Better than the +$12 for a new one.
Old 07-04-2021, 02:21 PM   #26
2017 Interstate Grand Tour Ext
Healdsburg , California
Screws in Cabinetry
Haven';t posted before, as I'm a relative novice in the world of Airstream (just sold our 2017 Interstate, and are picking up a Flying Cloud 25 TB at the end of the month). What I am not a novice in is cabinet making. We had screws loosen and fall out on the cabinets on the interstate. If you can tighten (not over tighten) before they fall out and work the holes too big, you can keep things happy, but my recollection is our cabinetry was made of particle board, and this has very limited holding power compared to plywood or solid wood.
Key take-aways:
1) Always make a correct size pilot hole. What is the right size? Look at the central "core" of the screw, not the thread around it. Make room for this core (just)! Too small, and the particle board will pucker, and chip, paradoxically providing less hold. Too big, and you will not have enough material for the threads to bite into, and allowing a certain amount of wiggling, which will cause it to fall apart quickly in a jostling Airstream.
2) Use centering drill bits as shown in posts above. If not the right size, use one a bit on the small side, and finish up with the correct size. Allignment counts.
3) Use the right type of screw. Ever assemble Ikea stuff? Then you've probably seen this type of screw. They look a bit funny (no point, very wide threads). Use these for composition board, they have vastly more hold. Here is a link to flat head versions of this: https://www.rockler.com/centerline-5...ickel-100-pack There are pan head versions available for applications that need those. Most of the "euro" style ones are PoziDrive, which looks like Phillips head, but isn't, which explains why assembling Ikea stiff can be maddening. You need to get a PoziDrive #2 bit, which is NOT available at you local hardware store.
4) it is easy to strip the hole in composition board. Tighten carefully. Once stripped, it is a pain to repair the wood to take a new hole. Kind of like you can back the trailer until you hit something, and then pull forward 6" to make it better.
bradah is offline   Reply With Quote
Old 07-04-2021, 02:25 PM   #27
Terra Nova Photography
2007 28' International CCD
Lakeside , California
Seems like something like this would be helpful. LOTS of options.
https://www.amazon.com/DEWALT-Right-...s%2C238&sr=8-5
BobCA is offline   Reply With Quote
drilling out rivets dhe9 Ribs, Skins & Rivets 9 02-08-2006 01:07 AM
Drilling out rivets MarkR Ribs, Skins & Rivets 5 06-12-2005 10:54 AM
Drilling out rivets... Andy R Ribs, Skins & Rivets 24 04-20-2005 12:36 AM
Trouble Drilling to Install Anti Sway Cams DEO Hitches, Couplers & Balls 21 02-26-2004 06:15 AM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 04:02 PM
