Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Oddities
Old 04-22-2018, 08:44 PM   #1
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
What’s this, can I fix it, is it under warranty?
I have a 2017 FC 23D, warranty is up in December 2018.
AS was in storage outside most of winter. I have it under cover stored in garage at home now, for about 2 weeks.
Noticed this peeling, plastic film, I think it’s the plasticoat. Should this happen on such a new unit?
Can it be fixed or dealt with?
Is it a warranty fix?
Thanks for any insights, I searched forums and didn’t find much on later models. Pictures below:
Troutboy
Troutboy is offline   Reply With Quote
Old 04-22-2018, 09:01 PM   #2
Journeyman
2016 25' International
Amherst , Massachusetts
Warranty issue. Don’t delay.
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 04-22-2018, 09:51 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Agreed.
The clear coat impregnation from Alcoa has failed. That cannot be repaired with re-coating, the panel will need to be replaced.
Looks to be the exterior just below the awning? That’s a big sheet I believe.
I had some of that peeling on the exterior rear top corner panel of my 2008... I tried all sorts of things to fix, Re-coat, seal, etc... but it looked bad no matter what [emoji20]
The local Colorado dealer has 1 airstream certified tech who can do panels. Timeless travel trailers has 2 people on staff who are trained by the factory. There is one other guy up near Longmont I believe, and that’s it for our area.
I’d get with JC and then see if you can slide into timeless at the end of the summer / in the fall. The factory worked with them on one of my warranty issues (AC replacement).
Either that or bring it to JC for the repair. I wouldn’t go anywhere other than those 2 places, personally.
wulfraat is offline   Reply With Quote
Old 04-22-2018, 09:53 PM   #4
Troutboy's Avatar
Parker , Colorado
It’s an outside top panel below the curbside awning, the big zip dee one
Troutboy
Old 04-22-2018, 10:00 PM   #5
wulfraat's Avatar
Sorry for the bad news, only way to address that is to replace the panel. I’ve been down that road on my last trailer.
Old 04-22-2018, 10:01 PM   #6
Troutboy's Avatar
Parker , Colorado
Crap! Can I wait until after the camping season?
Troutboy
Old 04-22-2018, 10:02 PM   #7
wulfraat's Avatar
Absolutely, but get your claim started now. It will take that long to get it into a good shop anyways.
Old 04-23-2018, 06:14 AM   #8
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Yep, sounds like a perfect reason to visit the Mothership
Old 04-23-2018, 10:25 AM   #9
Some Guy
djarrett's Avatar
1968 26' Overlander
2021 25' Globetrotter
Nashville , Tennessee
I’m gonna step out on a limb and contradict what everyone else is suggesting - if this is exterior and directly under awning, it is more likely a protective clear decal that is added over the Alcoa factory coating that is applied before they install the awning (which I believe is a late model practice) - if this is the case, it’s a strip that is about 8 inches tall and runs the full length of the awning. ‘IF’ what I’m saying is correct, this is an easy fix and possibly even a DIY process. Again, I may be wrong, but worth your investigating.
D
djarrett is offline   Reply With Quote
Old 04-23-2018, 04:20 PM   #10
wulfraat's Avatar
You can see the clear plastic strip you are referring to under the awning higher up in the photo. That’s Alcoa factory clear coat coming off.
Old 04-23-2018, 05:28 PM   #11
zapper's Avatar
2007 25' Safari FB SE
2017 30' Flying Cloud
Highland , California
Yep, I agree the delamination is too far down on the panel for it to be the protective clear tape. Sorry for the delamination. What a pain.
zapper is offline   Reply With Quote
Old 04-23-2018, 09:36 PM   #12
Troutboy's Avatar
Parker , Colorado
I sent the mothership some photos and they are trying to figure out what it is and whether it’s covered.
Also, I didn’t realize this, but that is ONE massive panel, for the entire curbside. To replace it means taking all windows, vents, the door, and water heater, etc off.
I’m wondering if it’s even worth it? Wouldn’t they have to take the inside panels out as well to buck rivet it back in place?
Seems like I may be better off living with it than tearing the entire AS down?
What would you all do?
Troutboy
Old 04-23-2018, 10:12 PM   #13
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
I suppose that depends on the size of the settlement check Airstream offered me to forego the warranty work.
TheGreatleys is offline   Reply With Quote
Old 04-24-2018, 04:34 AM   #14
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
If it's a warranty item, I'd schedule a week in Ohio and have them repair it as you described.
If not a warranty item, I would make (well, contract someone with skills to make) a creative, meaningful aluminum patch for that area.
Good luck!
Old 04-24-2018, 09:15 AM   #15
wulfraat's Avatar
Yeah it’s a tough one. That is a massive sheet. In the end I chose not to fix mine - but it was up high. It bothered me. If I had kept the trailer I probably would have fixed it. You’ll need to treat with corrosion-x so filiform corrosion does not start if you choose not to fix.
I am thinking the factory would “oversheet” it - and simply lay a second layer over top.
See what the factory says. It’s such a new trailer with a ton of aftermarket upgrades / investment, I’d be tempted to have the factory replace the entire panel and put it back to new.
Old 04-24-2018, 09:25 AM   #16
2019 27' Globetrotter
Salem , Oregon
There must be a better option than the factory. Ohio is not exactly next door. One would have to allocate 3 weeks of their time. 2 weeks back and forth and 1 week in Ohio (yawn).
Dave
NoResults is offline   Reply With Quote
Old 04-24-2018, 09:28 AM   #17
wulfraat's Avatar
Timeless Travel Trailers in Denver is the other option.
Old 04-24-2018, 09:56 AM   #18
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
After some type of settlement for damages, what about some type of aftermarket clear coat?-- Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 04-24-2018, 03:16 PM   #19
Troutboy's Avatar
Parker , Colorado
I like the idea of a patch, hmmmm maybe a nice trout cutout patch!
I have corrosion-x and will apply it. Thx
They asked me for more pictures, so still not sure how they plan to work it.
Troutboy
Old 04-24-2018, 04:32 PM   #20
W , New England
Indeed! Make it your own! (Take the settlement check too....).
There's a thread in here somewhere - search for "patches" or "show us your patches" - some truly marvelous creativity!
Then camp and enjoy the heck out of yourself! [emoji3]
Glue leak work done under warranty Kellerzal Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 01-20-2018 10:39 PM
2015 F-250 4x4 18,000 miles still under warranty richg Airstream Classifieds 0 05-20-2017 12:38 PM
Kenwood radio not covered under warranty AtlantaCpl Sprinter and B-van Forum 25 02-01-2016 12:19 PM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
