Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Exterior Storage Compartments & Access Doors
Old 03-12-2019, 11:59 PM   #1
1971 29' Ambassador
Gulf Shores , Alabama
Question Compartment Door Pop Locks 1971 Ambassador
I purchased two replacement compartment door pop locks from Vintage Trailer Supply for my 1971 Ambassador a couple of months ago. They're beautiful, but I've run into a problem with removing the old lock. I can't figure out how to completely remove it. I removed the operating part of the lock, but I can't get the shell of the old lock off. The base of the T-part remains on the outside of the panel, and the cylinder that contained the operating part remains on the inside. It will twist back and forth (limited by the trim piece on the door). The T-part on the outside and the cylinder part on the inside are two different pieces that are connected in a way I can't figure out. On the cylinder part on the inside there's a I guess I will call it a tang looking thing, that suggests if it were depressed in some way it might cause the two parts to release. The new locks look the same but they're different than the old lock in that the T-section on the outside and the cylinder on the inside are a single piece. With the old lock, the compartment door is sandwiched between the outer T part and the inner cylinder that used to contain the lock mechanism.
Please tell me how to take this thing apart.
TIA
Sam McKerall
SamWind is offline   Reply With Quote
1971 Ambassador Compartment Door Pop Locks SamWind 1970 -1973 Ambassador 0 03-12-2019 06:51 AM
Pop Goes the Rivet or Missing interior pop rivets 22FB Msherw 2005 and newer - Bambi all models 46 02-14-2019 03:57 PM
'78 Argosy MH Main & Compartment door locks Airhed Doors & Locks 0 09-13-2016 11:18 AM
Compartment door locks? Jeepers! 1956 - 1965 Caravel 0 01-07-2016 11:08 PM
source for exterior compartment door locks? stinky_hermi Doors & Locks 2 04-19-2007 05:23 PM
