Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Exterior Storage Compartments & Access Doors
Old 03-02-2019, 04:16 PM   #1
2017 20' Flying Cloud
Williamson County , Texas
Surprised by poor quality sheetmetal Fab
The rear storage compartment gasket was a bit wonky and not seated on my nearly new 20' FC, so I pulled it away from the flange and discovered the obvious problem was that the inner aluminum panel was not attached to the door frame for most of the perimeter, and the inner panel cutout was very uneven and ragged looking. Both these conditions were keeping the gasket from seating.
I was able to clamp the two edges together and add rivets as should have been done originally, and then trim the inner panel edge smooth and flush with the door opening. The gasket then installed easily and properly.
Pretty surprised at how awful this looked. Hard to understand how an assembler would have such zero pride of workmanship, so maybe they need better tools ?
SYC2Vette is offline   Reply With Quote
Old 03-02-2019, 04:22 PM   #2
Sag Harbor , New York
Welcome to the inconsistent world of Airstream quality control.
https://www.google.com/search?q=QC+q...com&gws_rd=ssl
Senior Management Failures: http://www.airforums.com/forums/f542...as-182914.html
https://www.google.com/search?q=Qual...=airforums.com
PS — The good news may be that most RV manufacturers are said to be worse than Airstream.
Old 03-03-2019, 06:41 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Does this mean we should settle for the "Best of the Worst"?
I wonder if A$ ever heard of a template?
Old 03-03-2019, 08:42 AM   #4
Photos
Seemed like the upload attachments was successful, but I don't see the photos as attachments so I will try again. In the image on the right you can see two "non-functional" rivets that just go thru the access door frame and do not attach to the inner sheet metal. I removed those rivets, clamped the joint, and added appropriate rivets.
Name:	AS SheetmetalGap_1.jpg
ID:	334866   Click image for larger version
Name:	AS SheetmetalGap_2.jpg
Old 03-03-2019, 09:10 AM   #5
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
But they got it out the door and sold, huh?
That's what makes the bottom line. Quality doesn't seem to.
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 03-03-2019, 01:06 PM   #6
2017 27' International
Antes Fort , Pennsylvania
Same problem with my 2017 FB 27 foot Int. Serenity. I have another annoying cut on my finger from the sheet metal. Healing slowly.
alphamale49 is offline   Reply With Quote
Old 03-03-2019, 03:32 PM   #7
mikesSE's Avatar
2007 23' Safari SE
ROSWELL , Georgia
Images: 14
IF you saw your new $150K Airstream ( insert celebrity ) without the windows and trim,you would have walked out on purchasing it,by the manner that they are chopped up.There isnt an airplane in the world with such metalsmithing cobbling.They arent built like aircraft,as it is told.
Mike & Nancy Gore WBCCI #2914 S E Camping Unit 012 Roswell,Ga.
mikesSE is offline   Reply With Quote
Sourcing Sheetmetal Panels propstrike Mechanics Corner - Engines, Transmission & More... 9 12-29-2016 03:15 AM
New Denali 2500 Pricing - a bit surprised Wanna EB Tow Vehicles 1 06-19-2016 04:49 AM
2015 30 ft International CCD poor quality control issues lyndamaxine 2011 - 2015 International 91 02-08-2015 06:53 AM
Mixed batteries and surprised with converter/inverter outofcontrol Batteries, Univolts, Converters & Inverters 14 05-08-2014 09:04 PM
