12-11-2018, 02:33 PM
1992 29' Excella
Virginia Beach
, Virginia
Looking for advice on installing gray belly wrap.
Happy Holidays,
I've purchased, cut into sections and dry fitted new .025 silver aluminum for the bottom flat panels of the belly pan. Since mine is a 1992 Excella. The side panels of my belly wrap are Gray. I've purchased the gray aluminum from Airstream, but I haven't cut it yet. I have some questions regarding cutting and installing it. I have a couple of compartments in my gray wrap on the street side. One for the electric cord and another one next to it contains an external water spigot and tank flush connection and a small storage bin for dump equipment. Is there anyone who can offer some advise on gray wrap installation for this area? I should probably mention that I do have the old gray wrap sections to use as patterns.
I'd like to get advise on best way to cut it and shape it. Is it thin enough to simply rivet at the bottom and curve it up to the shell after cutting. I'm sure anyone with sheet metal and or bodywork experience would be helpful.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
12-11-2018, 07:10 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Hi: I used a piece of the largest PVC pipe I could find. I think it was 6" in diameter. I used the plastic pipe as a 'mandrel" to gently form a radius on the side wraps. I then attached them to the side of the trailer first, and pushed them around to the belly pan seam. I used my floor jack and a 2x4 to hold the belly wrap kinda tight to the bottom of the trailer while I was popping rivets.
Hope this helps some. Your templates will be very helpful.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
12-12-2018, 06:05 AM
1992 29' Excella
Virginia Beach
, Virginia
Originally Posted by dbj216
Hi: I used a piece of the largest PVC pipe I could find. I think it was 6" in diameter. I used the plastic pipe as a 'mandrel" to gently form a radius on the side wraps...
David
Hi David,
I appreciate your input. That seems like something I could do as well. I do have a couple of questions.
- Did you tape one side of the aluminum to the pipe and roll the pipe across the width?
- What did you find worked well for cutting your aluminum?
I've done a shell off so I'm planning to attach everything to the bottom and flip the frame and set the shell in place and tack it up on the sides. Easy, haha .
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
12-12-2018, 07:03 PM
1986 34' Limited
1975 27' Overlander
Conifer
Me again: Tape would be a good idea. I just rolled it with my hands and gloves. My goal was to get a radius formed in the aluminum so it wouldn't buckle when I bent is around the outriggers.
I purchased a "cheap" powered shear to cut my aluminum sheeting. I paid about $50 for it and it still works good. See photo.
Assembling the bottom of the frame "sunny side up" is the way Airstream did it in their factory when I went on their tour. The tanks, some plumbing, some wiring, insulation, belly material, axles and shocks were assembled, and then the frame flipped over. Some folks use the gantries they made to lift the body off the frame to flip the frame over, rotisserie style.
I've not done a body off project. The frame work and reassembly I've done has been on my back under the trailer. Hard work.
David
12-12-2018, 07:19 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
I posted my very limited experience with belly wrap here>
http://www.airforums.com/forums/f476...ri-105774.html
Hope you can find something useful in it.
ps:
I did not have to pre-bend the curve. I found the metal flexed around the ends of the outriggers easily using hand pressure.
Alan
12-13-2018, 07:30 PM
1992 29' Excella
Virginia Beach
, Virginia
David
David,
Thanks for getting back to me. Someone else has also recommended a $50 electric shear. I believe theirs came form Harbor Freight. Thanks for the picture as well. How much metal did you loose per cut? That looks like quite a ribbon.
Here is a picture Gallery of our gantries and the flip.
https://photos.app.goo.gl/irSkWU6iEHiTcA4w7
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
12-13-2018, 07:34 PM
1992 29' Excella
Virginia Beach
, Virginia
ps:
Alan,
Thanks I read this your belly wrap thread and your floor repair thread. Very helpful. Thanks for posting them and thanks for sharing your thread with me.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
12-13-2018, 07:45 PM
1986 34' Limited
1975 27' Overlander
Conifer
The ribbon is about 1/4" wide. The tool kinda stops and starts as you're making a cut. It takes a bit of practice to get a straight cut. But I find it way better than hand metal snips.
David
12-13-2018, 08:31 PM
1992 29' Excella
Virginia Beach
, Virginia
David
David, Once again, thank you. Yes I've worked with something similar in the past, but it was a drill attachment. Worked the same I think. I don't remember it cutting out a strip. I only used it a few times and it's been 15 years ago at least and at this point I can't remember what I had for breakfast let alone how that went.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
06-24-2022, 09:25 AM
1992 29' Excella
Virginia Beach
, Virginia
Wow, has it really been three and a half years? Afraid so. So, using a slightly modified version of the method suggested by David (dbj216), we finally successfully rolled our final two lengths of great wrap. Both of these were quite long and beyond what my wife and I alone could manage. One was about 9' long in total and the portion we needed to roll was 7' of that. The other section was about 11-1/2' long and the portion that had to be rolled was 9' long. When our other assistants feel through, I asked a neighbor if he'd mind helping and he pitched right in. What also made the difference was using a 2-1/2" x 3/8" x 8' length of pine (that I made by re-sawing a 3/4" piece of premium pine) as a backer to stiffen the edge of the aluminum. It also distributed our hand pressure over a larger area along the edge enabling us to get a consistent roll. I hung it along the edge of the aluminum by taping it to the shiney side with small steps of duct tape. The PVC pipe is 4" ID x 10' schedule 40. Hard to explain, but here's some pictures. No, pictures of is doing it for obvious reasons, but I hope these help someone else. Phyllis is kneeling in her position. Don, my neighbor and I were at either end on the opposite side facing Phyllis and we rolled it toward her. By kneeling on the gray wrap, she kept it from moving. Attachment 418198Attachment 418199Attachment 418200Attachment 418201Attachment 418202
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
06-24-2022, 06:51 PM
1986 34' Limited
1975 27' Overlander
Conifer
Glad you finally got a "round toit" for your project. The dark grey belly wrap will look good on your Airstream. Airstream was doing this in the mid-eighties as our 86 Limited had dark grey belly wraps. See photo.
David
06-28-2022, 07:53 AM
1992 29' Excella
Virginia Beach
, Virginia
David
Purdy. Looks great. Thanks again for your advice.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
