06-21-2002, 01:06 PM
Stone Guard/ Keep it or Remove it?
Is this stone guard a desirable item? Looks kinda ugly. I guess I could polish it up. The body behind it is perfect. Was this an option? I would rather have a window cover. It would really look goofy if I had both guards don't you think?
06-21-2002, 06:19 PM
Just a member
1978 28' Argosy 28
Lutz
It depends on where you plan to tow. Lots of back country, gravel roads I wold keep it. I did not have a lower rock guard on my 77 Sovereign but you could see the wear from rocks etc. I had the rock guard over the front window. I think it is a better option as the windows are big $$$$.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
06-21-2002, 08:10 PM
1983 27' Excella
Airstreamville
, Kansas
The rock guard looks fine to me, it's there to keep the skin from getting dinged up not to be stylish. I would put on on the front window too you'll wish you had if the window eats a rock.
John
06-21-2002, 10:32 PM
1965 20' Globetrotter
Houston
Polish it up. They look pretty cool all nice and shiny. This is also going to stop that 65 mph rock from denting the shell.
Regards;
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
06-22-2002, 07:22 AM
Contributing Member
Austin (Hays County)
Keep it!
Flying gravel is a fact of life here in Texas. The gravel guard is a must-have option for me.
I would polish it up and keep it.
John W. Irwin
WBCCI #9632
06-22-2002, 09:55 AM
1986 25' Sovereign
Southern Middle
If you want small dents throughout the front of your trailer then by all means remove it. I have a rock guard over my front window but none over the front lower panels. I have had 4 new dents in the front panels that have made me sick. They will stick out like a sore thumb when I polish my trailer. I'm sure you will feel the same way once you drive through gravel and later hit the blacktop. A rock thrown from a tire at 60-65 wrecks havock with soft aluminum skin. Just my 2 cents worth. Craig
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
06-23-2002, 02:00 PM
2004 30' Classic Slideout
Fenton
Personally I would keep the stone guard.
Considering if mine ever got too ugly or took a big hit, I could replace them. I think the cost of replacing the stone guard is a lot less than removing and replacing a front panel.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
06-24-2002, 07:40 PM
Moderator dude
1966 26' Overlander
Phoenix
Another reason
I do not have a guard like your pic. And I lost a tire (right rear) on my van the last time I towed. The tread flew off. It was an older tire with tread and a warrantee. And it did not cover damage to my van or the beauty mark on my bullet. Just got a new tire
>>>>>>>>Action
06-26-2002, 11:07 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
what do you suppose a lower stone-guard would cost? I'd assume that model #/size of the trailer shouldn't matter much...they all look the same from the front! just curious...perhaps I'll add one, if they don't cost an arm and a leg.... Oh, and how do they attach?
06-26-2002, 01:09 PM
1986 25' Sovereign
Southern Middle
Check www.inlandrv.com. I believe they have them in stock. I priced them at one time but have forgotten what they run.
Craig
AIR #0078
3.73 rear end
