09-11-2020, 12:39 PM
Elizabethtown
, Pennsylvania
Henschen axle hub
Does anyone have a 7200 lb henschen axle hub for sale??
09-11-2020, 07:15 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Henschen was purchased by Axis (sp) in about 2011. Then Dexter bought that whole business in about 2015. Dexter calls them 'torque flex" axles now.
Most Airstream axles are in the 3000 pound axle rating range. A 7200 pound axle would be a big mother for an Airstream trailer.
Hub can mean a lot of things. The torque flex axle has swing arms with spindles welded to them and then bearings and a drum brake installed over that. Maybe a photo of the "hub" you are looking for would be helpful.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
09-12-2020, 10:02 AM
Elizabethtown
, Pennsylvania
I need the brake drum.. it’s actually a 14000 horse trailer on henschen axels.. I found out that henschen is no longer in business and that they were used on airstreams.. that’s why I’m at thus forum.. just trying to find the drum to avoid having to replace the entire axle..
09-12-2020, 10:25 AM
2013 31' Classic
billings
, Montana
Research for an Airstream junk yard....several sites for vintage as
09-12-2020, 11:39 AM
1974 Argosy 26
Morrill
, Nebraska
Have you checked with Dexter?
You might try Redneck trailer supply.
09-12-2020, 12:16 PM
Retired.
, At Large
A 12" brake drum is a 12" brake drum, at least as far as modern parts. The Airstream drum you asked for will not fit the spindle you have, you'll need one for 7000 pound capacity. The outer bearing is larger.
09-12-2020, 06:20 PM
1986 34' Limited
1975 27' Overlander
Conifer
Thanks, that explains your post.
I bet your local utility trailer supply would have the drum, bearings and brake assembly if needed, for you. If they are a Dexter distributor, that is a plus.
David
09-13-2020, 02:47 PM
Elizabethtown
, Pennsylvania
Dexter does not make a replacement hub for this axle. I cannot find one for it. I’m going to have to replace the axle unless I can find someone that might have one for sale or on a trailer at a salvage yard
