I'm repacking the bearings on my '08 16' Bambi International, Ocean Breeze. I Want to make sure I'm getting the correct bearings in case one or more need to be replaced. Anyone know the actual part numbers? Inner, Outer & seal.
thanks much.
Darn if I can remember what I did 18 months ago when I needed the same. But I can tell you that I called Dexter Axle and gave them my airstream serial number and they sent me the axle build sheet and the lift kit info for my 06 Safari. I believe it had all I needed. I bought the seals and lift kit from Auto Safety House in Phoenix, a Dexter dealer. 800.352.5355. It’s worth a call.
Good luck,
Steve
