Old 05-27-2004, 10:55 AM   #1
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Tongue - say ahhhhh
Along with replacing axle, springs wheels etc - I'm thinking about replacing the hitch that is attached to the tongue on my 58. I figure that I would go to the next size ball and have an updated attaching mechanizm. What do you all think? How hard is it to unweld the old one, and when you do unweld it does it weaken the frame?
All thoughts appreciated
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 05-27-2004, 11:20 AM   #2
Images: 59
Ken,
When we replaced the coupler on my '59 with a larger one, we were able to clean up and weld shut the openings where the front of the frame is open to the elements and dirt. I think it's a great idea.
This picture is a little cruddy because I just treated it with POR-15 metal prep, which leaves a coating on the metal.
Old 05-27-2004, 11:52 AM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Originally Posted by markdoane
Ken,
I can't help but ask this:
Is that upside down, or what??
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 05-27-2004, 11:55 AM   #4
Images: 55
Nah! its the new style coupler. Haven't you seen those?
Tripp
Tripp is offline   Reply With Quote
Old 05-27-2004, 12:04 PM   #5
LOST , Hawaii
Thumbs up
Tripp
No weight distribution needed.
John
Old 05-27-2004, 12:05 PM   #6
1984 29' Sovereign
Savannah , Missouri
Tripp
Noooo, that's BS.....lol
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 05-27-2004, 12:16 PM   #7
Images: 55
My own sick sense of humor. Sorry!
Tripp
BTW. Markdoane (Don) does excellent work. Anyone considering frame/shell separation should read his posts. 59Toaster and a few others also come to mind as well. I guess it makes sense, if you're gonna go all the way, do it right! My 56 frame off is looming closer!
Old 05-27-2004, 12:48 PM   #8
Images: 59
ciao
53FC
Awww.
Gotta start over. Thanks for pointing that out.
Hey, can't I just put the ball upside down in the reciever?
Old 05-27-2004, 01:18 PM   #9
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Its an Austrailian Hitch. You're just looking at it from North America.
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 05-27-2004, 01:19 PM   #10
1984 29' Sovereign
Savannah , Missouri
Thumbs up Hey..
Awww.
You might ask CAN-AM to fix it up for you...lmao
Looks like a nice piece of art~
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 05-27-2004, 02:19 PM   #11
Images: 59
Ken,
back to your question:
I took me about three hours with a grinder to get the old coupler off. It's not a pleasant task.
If you have the time, space, and inclination, I think taking the axle off and turning the frame over makes the job of replacing and painting the frame a lot easier.
Two men and a boy can flip the frame without any equipment.
Old 05-27-2004, 02:59 PM   #12
Ken J's Avatar
Durango , Colorado
Images: 14
Yes that's the kinda hitch I was looking at - an upsidedown hitch - its new physics
Anyway - thanks for the info - you confirmed my thinking.
My thinking if I have new coupler, new running gear - life is good. Plus a larger ball is a stronger connection - probably overkill, but won't hurt.
Do you have a box frame? Mine is a C frame so don't see a need to seal off the end - I do think its a great i
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 05-27-2004, 03:07 PM   #13
Ken J's Avatar
Durango , Colorado
Images: 14
oops pushed the button too quick.... Anyway I do think its a great idea - should do that on my 75 instead of stuffing steel wool.
Did you have any problems finding a hitch to fit - most of the newer frames are 4-5 inch - mine (or yours and mine) are 3 inch.
My plan is to have the shop who is doing the welding for me cut it off - my understanding is they have tools to do that. I'm also going to have some cross member welding done - except all mine is being done with the shell and wheels still on the trailer .
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 05-27-2004, 04:08 PM   #14
Images: 59
Ken
Nope, my frame is 4".
Old 05-27-2004, 06:06 PM   #15
Ken J's Avatar
Durango , Colorado
Images: 14
Hmmm I'll have to check mine - I assumed it was 3 inch "C" channel
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 05-29-2004, 07:42 AM   #16
Ken J's Avatar
Durango , Colorado
Images: 14
Don - Your right, went and checked my frame yesterday, it is 4 in also. Guess gotta get my eyeballs cleaned a bit - soon as I looked at it I thought thats a big 3 inches - sure enough it was 4. It is C channel though.
Another little problem is now that I have all the cabinets out, when I jump up and down, the walls bow in - think I have shell seperation - gotta get the belly off next and see how its all bolted together. The good news is the only rot I found is in the front and in a small area, so my thinking is the outriggers are broke, or the floor is loose from the frame - from what I can tell, this trailer has been over some pretty rough roads. Any thoughts on this would be appreciated.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 05-30-2004, 12:40 AM   #17
upallnight's Avatar
Lightbulb
Ken
I know your post wasn’t directed to me but I might be able to give you a little insight. I found I had a problem with mine when I brought it home, my brother-in-law was following me and he said the bumper was loose. He said it was moving up and down about 4 inches while traveling down the highway, the PO had replaced most of the floor and had not bothered bolting the shell back down to the floor, thus the problem. Another problem was he had severely overloaded the trailer. You can see some of the floor patches in the link below:
http://www.airstreamphotos.com/photo.../cat/500/page/
I am replacing the floor without removing the shell, I’m going to cut the new floor 88 1/8" then split it in half, the 1/8" is for the saw curf. I have welded in a 2" wide strap the length of the trailer on the centerline for the plywood to rest on, it will also be a platform to bolt to. This is just a poor mans way of doing a complete floor replacement with only one person. See picture in link below:
The strap welded in has added a lot of stability to the frame without adding a lot of weight. Once the plywood is bolted down at the seem I believe it will be as strong as a complete sheet, anyways I'm doing this alone and can't lift the shell. Also in the second picture you can see part of an outrigger I welded in. The one that was there went on a walkabout. Don't know what happened to it.
Leonard
Leonard
LotalaborAZ
upallnight is offline   Reply With Quote
Old 05-30-2004, 08:51 AM   #18
Ken J's Avatar
Durango , Colorado
Images: 14
Yea, it kinda helps to have the shell bolted to the floor.
In my case the PO cut the last few cross members - so I know I've got to get those fixed.
My floor is origianal so I know something is bolted to something - from what I can tell I don't have very much floor rot, so either the bolts have pulled through somehow or I've got some broken out riggers or one more possibility is because the cross members are cut, its allowing the whole thing to bow, anyway, I need to get under there and pull the belly, get my wife to jump up and down while I watch whats going on. I'll you all posted
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
paint for the tongue tinsltootsie Clearcoat, Exterior Paint & Trim 16 12-07-2005 09:15 AM
Disabling Tongue Jack Cracker Jacks, Stabilizers, Lifting and Leveling 10 11-14-2003 11:32 AM
tongue paint B25guy Clearcoat, Exterior Paint & Trim 1 08-28-2003 07:52 AM
Tongue weight, how determine? pilgrim_still Towing, Tow Vehicles & Hitches 6 06-17-2003 03:45 PM
New tongue layout FrankR Cleaning, Stripping & Polishing 0 03-07-2002 08:51 PM
