Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 06-12-2013, 05:50 AM   #161
1987 25' Sovereign
Oregon , Ohio
Just getting around to telling about last weeks travels. Went to our combined unit rally in B.G. Ohio. Only about a 60 mile round trip and the Andersen preformed well. At the rally about 10 people wanted to know about the Andersen, the Quick bite, and the EZ connector wire harness. Everyone liked and understood the way the all worked. Of the ten most were thinking using one, two, or all three of them. I did tell them that in my opinion the Andersen works best with full sized pickups and vans, and not so well with SUV's and sedans.
msmcv51 is offline   Reply With Quote
Old 06-18-2013, 02:09 AM   #162
themartaman1's Avatar
1972 23' Safari
Stockbridge , Georgia
For $200 more you can get the Anderson and have a product made in USA with sway control.
themartaman1 is offline   Reply With Quote
Old 06-19-2013, 06:20 AM   #163
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The less expensive systems usually cut corners. We bought 10 Curt weight distributing hitches at work. They are just cheesy. The method of holding the torsion bars in is just terrible. All 10 are broken after not even 6 months. You always get what you pay for.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-19-2013, 08:28 AM   #164
HowieE's Avatar
Princeton , New Jersey
Images: 12
From your earlier post can i assume your comment about less expensive systems refers to the EQ hitch getting what you pay for and not the Andersen?
2004 Excursion 4x4
Old 06-20-2013, 05:49 AM   #165
m.hony's Avatar
2013 30' Classic
Speaking in general that principal applies. My point is- don't get the least expensive hitch and don't go strictly on written specifications. Real life and specs on paper are 2 different things. The specific brands I mentioned are the ones I have personal experience with. The Andersen hitch is a great product for sure, but I have never used one. I think the Hensley Arrow may also be a good one, but I have never had one, and I have only seen them in person twice. Do I think the Equal-I-Zer is a good hitch? Yes. Do I think there may be better hitches out there? Yes.
TAC #MS-10
Airforums #70955
Old 07-01-2013, 08:24 PM   #166
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I don't always follow all of the rules
Just returned from a 23 day 4000 mile trip with our '74 Argosy 26'. From Henry, NE to Vancouver, BC and back.
My TV is an '08 Tundra
I use the Andersen Hitch and a Marvel coupler rated at 20,000#
The TV has "P" rated tires With 40 PSI in the rear tires
The trailer has "ST" rated tires with 55 PSI in all 4 tires
The trailer weighs in at 5,500# loaded for travel
I also use air bags on the rear axle with 28# in each bag.
Here is a pic of the setup.
http://i1166.photobucket.com/albums/...8/IMG_4049.jpg
There was one issue with the Andersen Hitch. And it only happened one time. The threads on the tensioning bolt hung up on the washer welded to the square tubing. Note in the following two photos. The chains are slack and the bushings are compressed.
http://i1166.photobucket.com/albums/...8/IMG_3244.jpg
http://i1166.photobucket.com/albums/...8/IMG_3243.jpg
The brackets did not move throughout the entire trip.
When setting up the hitch I follow Andersen's instructions, but don't count the threads. I measure the compression of the bushings. Tightening the nut until I measure 3" outside to outside on the washers at each end of the bushing.
I do feel the air bags on the rear axle of the TV are a big plus and help with the Andersen Hitch. Requiring less tension on the bushings to obtain the "steering geometry". As you can see in the first pic. The truck and trailer are riding in the correct plane.
We drove in 50 MPH headwinds thru driving rain for 3 days heading northwest thru Montana. Driving at 60 MPH. Experienced no porpoising or sway problems the whole trip. The water was deep enough on the hiway that it knocked one of the hub caps off.
There were no problems with the Marvel Coupler. Even though the latch handle raises up when hitched. The pawl is securely nestled with the ball.
I meant to take a pic of the ball to show the wear marks. But haven't done it yet. But looking at the top of the ball, with the receiver being at 12 o'clock. There are 3 points of contact on the ball. On at 10 O'clock, one at 2 O'clock and one at 6 O'clock. Each being about an inch long and about 1/2" below the top of the ball. The marks are what I would consider normal, with no signs of gouging.
Here is a close up of the hitch when set up.
http://i1166.photobucket.com/albums/...8/IMG_4052.jpg
http://i1166.photobucket.com/albums/...8/IMG_4050.jpg
http://i1166.photobucket.com/albums/...8/IMG_4051.jpg
And last. Do you think this guy has a steering geometry problem?
http://i1166.photobucket.com/albums/...8/IMG_4048.jpg
Old 07-01-2013, 09:41 PM   #167
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Using air bags to lift the back of the truck is not weight distribution, it's only lifting the back of the truck. Weight distribution is needed to restore not only the geometry of the front axle, but to restore handling and braking characteristics of the truck as well as a balanced payload.
My experience with the Andersen bushing compression compared to yours indicates you have little tension on them; that would of course keep the brackets from moving. And indicates little weight distribution.
Andersen has warned not to use the hitch with this coupler, it can wear he latch and uncouple from the trailer. The looped chain may prevent this, but how do you know.
Indeed you don't always follow the rules, but I would hope this is not taken by others as a safe towing setup.
doug k
Old 07-01-2013, 10:04 PM   #168
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Andersen talks about the Atwood coupler not the Marvel coupler. They are totally different animals.
I won't get into the weight distribution discussion.
This combination works for me. The handling is solid.
I would not recommend the Andersen on a trailer larger than mine. And would be skeptical as to how effective it is without the airbag system. Since the compression of the bushings have their limits.
IMHO
Old 07-02-2013, 06:40 AM   #169
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Doug, you say Andersen says that the coupler can come uncoupled from the ball. Can you sight one case where this has happened with the posters Marvel coupler or with any other coupler? Also how can you tell a poster that they are getting little or no weight distribution when they say they do? Still waiting for you to post actual issues that you experienced with the Andersen WD System.
MICHAEL
Old 07-02-2013, 08:40 AM   #170
dkottum's Avatar
IMHO
TG, here's my Atwood coupler and the Andersen. They look to be the same animal.
I also had 4,000 miles on the hitch and thought things were good. I wanted it to work and was overlooking reality. I was not getting enough weight distribution and recalled instances where the steering felt light on slippery roads, and pulled off the road for the day.
There also was concern about flexibility in vertical motion, such as driveway approaches. When I tightened the chains, there was virtually nothing left. Unlike the spring bars of a conventional hitch which flex, I noted the rigidity of the hitch caused the back of the truck and the front of the trailer to lift when going over these steep approaches. That's a lot of twisting on the truck receiver and trailer A-frame. It was apparent when I removed the hitch and found the bracket mounting holes elongated. The front lower side banana wrap on my trailer was torn loose from its mounting rivet; I cannot affirm this is from the hitch but it happened while it was used.
There was also heavy wear on the Andersen ball from the heavy forces on it, similar to what you describe. That doesn't look right. The friction material in the hitch began to squeeze out the top. That doesn't look right. These imply to me there is too much horizontal pressure being applied, even though weight distribution was not (could not be) fully applied.
The incompatibility of the hitch with late model Airstream couplers was the last straw for me. I became convinced Andersen had not fully evaluated and engineered the hitch. I agree it may be useful on very light trailers. The fact that they are selling it to be used on trailers as heavy as mine, even twice as heavy, seems irresponsible.
They are apparently satisfied letting users buy it and work out their own solutions to its shortcomings. Their are heroic innovations by users in the other Andersen thread to get this thing to work, including yours and mine, and it still cannot fully accomplish its basic weight distribution function.
doug k
On edit, am not able to upload the photo.
Old 07-02-2013, 09:43 AM   #171
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Doug;
The Atwood coupler has the infamous "shark fin". Which is supposed to keep the pawl mechanism in place when locked. Apparently they are shear off in some cases.
The Marvel coupler has no such mechanism. The pawl
lift bar is smooth. No notch. The lock mechanism is set farther back on the coupler. It does not have and never had the "shark fin".
When the ball is in the coupler socket and the lock mechanism is set. The pawl comes up against the bottom of the ball. The pawl rides in a channel and cannot ride up beyond the point of where it nestles with the ball.
I have increased the tension on the bushings to where the measurement I mentioned above is 2 1/2". This resulted in too stiff a ride. So I backed it off to the 3" dimension.
I believe that it is possible to put too much tension on any weight distribution system. The old add showing an A$ hitched to an Oldsmobile Toranado proves that. With enough tension on any WD hitch, you can literally lift the rear axle high enough to lose traction. This could and probably does cause handling problems different from the front axle being too light.
As with any mechanical device. There are limitations. Anyone using a WD system should have an understanding of the system. And how to adjust it for their particular needs.
If I felt I was putting myself, my family or other drivers in danger. I would not use this device.
I will continue to monitor the system closely and look for anything that changes.
Perhaps it is the fact that this particular Marvel coupler is rated a 20,000 pounds that makes the difference. I have another trailer with a Marvel coupler rated at 30,000 pounds and it is identical to the one on the Argosy. As far as the latch mechanism is concerned.
Old 07-03-2013, 10:00 AM   #172
floridalarry's Avatar
2017 23' Flying Cloud
Ormond Beach , Florida
Andersen and the Atwood (Marvel) coupler
Let me state that this will be my last post on this tread. After finding the incompatibility with the Andersen and the Atwood 88010 (which is the same as Marvel) costing me a new coupler, then not being able to put the correct amount of pressure on the front axle of my 2012 Nissan Armada without putting so much pressure on the bushings that it ruined the chains and sleeve material and being stuck in NY waiting for new parts from Andersen, I bought a Blue Ox to drive home. When I got home, low and behold the replacement parts where here from Andersen.
Well, to make a long story short, I have a slightly used Andersen, with new chains and sleeve material for sale . . . cheap. Contact me.
Larry & Linda Scovotto
WBAC #1021
Ormond Beach, FL
1966 20' Globe Trotter
2015 Nissan Frontier SL
floridalarry is offline   Reply With Quote
Old 07-03-2013, 10:05 AM   #173
I can. It happened to me. I noticed that the front of the shark fin was to completely sheared of when I was about to leave the Florida State Rally for home. When I got home, I began to raise the jack to take the tension of the chairs and the TT popped of the ball. The only think that was holding the TT on the ball was the tongue weight. Cost me a new coupler.
WBAC #1021
Ormond Beach, FL
Old 07-03-2013, 10:07 AM   #174
AWCHIEF's Avatar
Images: 33
Larry, I have heard good things about the Blue Ox. Good luck, hopes it works perfectly and you never have any issues with it.
MICHAEL
Old 07-03-2013, 02:56 PM   #175
Kevin245's Avatar
Mod Mode...
The staff is giving this thread a holiday break for the 4th. Please take this time to enjoy Independence Day and when the thread reopens let's keep things civil and save the fireworks for holiday events going forward.
On behalf of the site team
William C. Swinney
Old 07-07-2013, 02:10 PM   #176
Kevin245's Avatar
The holiday break is over and this thread is open. Please keep things in compliance with the site rules.
The site team
William C. Swinney
Old 07-07-2013, 02:42 PM   #177
2010 25' FB Flying Cloud
Davenport , Iowa
TGTwinkie; Are you sure that you were not looking at a old DR Pepper bottle? That was their old logo. 10 2 6.
Just kidding.
I have been following the the thread on the Andersen, which I have. I have not had any troubles so far but there is that doubt. I also called Andersen and sent them pictures of my hitch and set-up. They assured me that everything was OK, but to watch it. I was also told that they (Andersen) was in contact with Atwood for a possible modification but nothing had been finalized. I still have my EQ as a backup.
I'm surprised that the "FEDS" haven't formed a agency to monitor RV'S.
Airtandem is offline   Reply With Quote
Old 07-07-2013, 03:17 PM   #178
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Just kidding.
That would be great if Atwood and Anderson could come up with a fix to the coupler issue that doesn't include replacement. I'm keep in an eye on mine. So far okay, and wear on the ball indicates a good grip remains under the ball.
kscherzi is offline   Reply With Quote
Old 07-07-2013, 03:53 PM   #179
Merkel , Texas
Andersen hitch experience
I posted earlier on the massive thread concerning Andersen hitches. Since this is an Andersen users thread, I will share my experiences. My AS is an 06 25FB, TV is 08 Ford 3/4 ton diesel. The coupler is the infamous 88007 Atwood. When I installed the hitch, I carefully followed the instructions. I only used the set screws along with the bolts to hold the brackets in place. However I used a cheater bar to accomplish the 3 additional turns called for after the set screw made contact with the frame. In positioning the brackets I was very careful to pull the chains as tight as possible to determine their location on the trailer frame. I found what I thought to be the proper tension on the chains to be achieved by having 5 threads exposed on one side and 6 threads exposed on the other side.
My first use was a trip of approximately 1000 miles to Big Bend NP. When I got home I thought there was some wear on the "sharks fin". To add strength to the fin, I welded a bead down each side so it was held not just from the back, but by being welded down each side to the top of the coupler. The latch flares enough on each side so that when it is closed the weld does not interfere with it and the holes for the pin line up in the normal position.
After reading the posts on the previous thread, I purchased an Atwood 81911 and a 88061 repair kit for the 88007. Before we left for Alaska, I decided to start with the original coupler as modified, and take the repair kit and new 81911 along as insurance. I also adopted TG Twinkies "belt AND suspenders" approach and put a safety chain over the hitch. I also followed idroba's suggestion by using a small amount of grease on the ball. I also used it on the latch and sharks fin. I drove from my home in Texas up through MT into Canada and up the Alaska Highway. We went to Homer, Seward, Anchorage, and Fairbanks. We returned via the Cassiar Highway through BC and into Washington, Oregon and Idaho back to Texas, in excess of 10,000 miles.
The brackets on the frame have not moved at all and the only wear has been a small amount on the ball and on the chain. I failed to apply grease to the chain in a timely manner or some of that wear could have been mitigated. I am a happy Andersen user.
afneill is offline   Reply With Quote
Old 07-07-2013, 05:39 PM   #180
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Airtandem;
Dr. Pepper is my drink of choice. I do remember the old bottles.
