Old 08-31-2010, 07:58 PM   #1
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
Tow Vehicle Consultant
I'm trying to pull a 34 ft Limited with a Yukon 5.3L. Want to go out West next year and run around in the mountains for a while. I think I need a new vehicle (judging from my white knuckle event getting out of a fishing camp on Dale Hollow lake this Summer - 30 seconds of 9MPH at 1800RPM with cliffs all around). Can't get any straight talk from the dealers and all I see from most of the forums is to go with a 3/4 ton diesel. Anyone know of a consultant (I don't mind paying a fee) that can advise me on a tow vehicle that isn't "overkill" but is comfortable to drive with confidence? I just installed a ProPride hitch and it solved my sway problem but the Yukon just doesn't seem to have the guts to pull it uphill. Regards, Don Hetzler.
Emh142 is offline   Reply With Quote
Old 08-31-2010, 08:04 PM   #2
1960 22' Safari
in the wilderness , The great Mojave Desert
Frankly you need torque for a 34 footer in the mountains. If you want to be relaxed with plenty of go under your right foot. Diesel or a V10 is the way to go. If you can get by with less then your choice is a big block.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 08-31-2010, 08:09 PM   #3
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I agree with Goin camping....diesel or a V10 is a must for you. I've heard good things about the new Ford V8 but its early yet.
4RXLA is offline   Reply With Quote
Old 08-31-2010, 08:25 PM   #4
r carl's Avatar
Lin , Ne
Your dilema is easily solved by buying a 3/4 ton suburban with a 6.0 or 8.1L engine and switching your ProPride to it.
Old 08-31-2010, 08:29 PM   #5
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
Cummins is the way to go.
willyd is offline   Reply With Quote
Old 08-31-2010, 09:56 PM   #6
r carl's Avatar
Lin , Ne
Your love for dodge is well taken, but there is nothing more irritating than a ford or dodge diesel pulling into a campground hammering and clattering.
Old 08-31-2010, 10:03 PM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
The newer diesels are not nearly as loud as they were in the past.
If you want to stay with gas, you really need to find a Suburban 2500 with the 8.1 liter gas engine or a Ford Excursion with the V-10 gasoline engine. Neither of these is available new any longer. You may be able to find a good used one, though.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 08-31-2010, 10:19 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
My ideal tow vehicle would be a newer Suburban with the 8.1 (which was only ever available in a 2500 chassis). I would think it would work fine for what you're doing. The 8.1 doesn't have much more horsepower than the 6.0 but it develops it at considerably lower RPMs.
I don't believe that the diesels perform much better for towing though I realize opinions vary. But most people are comparing it to the 6.0.
I don't think there are any substantially better choices, unless you want a pickup.
I will note that I have an older (1997) Chev 2500 longbed with the 5.7 and am really quite happy with it except for the lack of seating. Though it is a 4x4 and I am not afraid to drop the transfer case into low range if I'm going up a steep hill with the traylah.
Old 09-01-2010, 12:06 AM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, the only way that I can see that Yukon working, would be to replace the differential gears with 5:88's. Other than that, you need a real truck to pull that real trailer.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 09-01-2010, 06:22 AM   #10
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
What part of that don't you understand?
The voice of experience?
Been there/done that?
You should re-read your post...get out your checkbook, and go drive one of the new diesels.
They are all amazing.
Beg/borrow or steal a test drive WITH A LOAD behind you. Driving an unladed truck doesn't tell you much about the towing prowess...
You need a substantial TV for that rig...don't kid yourself.
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 09-01-2010, 07:34 AM   #11
_
I'm trying to pull a 34 ft Limited...
Anyone know of a consultant...
consultant?... there are 100s of them right here...
straight talk?...also here
instead of asking OTHERS what to buy, post examples of what YOU think might work...
then the members here can offer insight into the vehicles listed.
pick a brand, pick a model, pick a color and post it.
it would also be useful to post DETAILS about the trailer.
34s and limiteds span a LOT of years and widths and weights...
details matter.
trailer life publishes an annual booklet/electronic list of ALL the vehicles available in north america...
the basic towing specs are included on that list, so it's quick n easy to scan n find the candidates...
________
so as a consultant, the first suggestion is YOU do the work and discovery process.
be assured this group will provide a few straight answers.
cheers
2air'
Old 09-01-2010, 07:52 AM   #12
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
When we brought our 30' classic home from Ohio, I towed it with a Sierra 1500 that I owned at the time.
When I bought the AS, I suspected that a new tow vehicle would be a likely requirement and the ride home confirmed that.
the 1500 handled it "sort of ok" on that trip, but the terrain between Findlay Ohio and our home couldn't be much flatter and we like to travel right across the continent.
I also had the feeling that with this length and weight of trailer, I was only barely in charge - not a real relaxing experience, pretty tight grip on the wheel!
After digging deep in my pockets and moving to a Sierra HD2500 diesel and adding a Hensley hitch, I am very happy with the setup - I don't think it could be much more of a match for all conditions. It just sails up the mountains in the south west!
If GM isn't your choice, I don't doubt the Ford or Dodge comparable 3/4 ton diesel would do just as well for you.
I don't know the weight of your trailer - ours has a dry weight of about 7300# I believe.
I would go this route again in a heartbeat. We also use the vehicle as a daily driver. It can be a bit of a pig to park at times, and even being diesel costs a bit more in fuel that a smaller car. but we are both retired and it seemed to me a financially better option than ownership cost of two cars.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-01-2010, 02:17 PM   #13
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I am happy with our setup (2009 F150 5.4 and '97 34' with ProPride hitch) in my part of the country Southeastern US. I would NOT take my setup into the Rockies or any real mountains (the Appalachian chain doesn't count). I would either by a diesel or slap a supercharger in my current truck. IMHO a normally aspirated V8 doesn't have the necessary power to climb mountains. You will loose approximately 3% of your power per 1000' in altitude gain. That means by the time you top a 10,000' pass you have lost one third of your power.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 09-01-2010, 03:04 PM   #14
1986 32' Excella
St. Petersburg , Florida
We have a 32' Excella and pull it with our Chevy 2500HD/6.0gas/4.10 rear/Hensley hitch, with 150.000 plus miles on it. She still pull great, but we are going to be on the road alot more. Since General Motors became Government Motors, I'm going with either
a Ford F-350 4x4 diesel (non-dually) or over kill it with a F-450 4x4 diesel (dually). I've driven both and I'm sold.. Good Luck
yenko302 is offline   Reply With Quote
Old 09-01-2010, 03:09 PM   #15
Ag&Au's Avatar
Port Orchard , Washington
I'd be happy to be your consultant at my customary $500/hr rate.
Regards,
Ken
Old 09-01-2010, 04:41 PM   #16
r carl's Avatar
Lin , Ne
Originally Posted by yenko302 View Post
Since General Motors became Government Motors, Good Luck
They all 3 got bailed out. GM is making big money now and paid back the loans i seen on the news last week.
Old 09-01-2010, 04:45 PM   #17
Vintage Kin
Fort Worth , Texas
Take the trailer to a certified scale -- full water & propane -- plus a good approximation in weight of what you travel with. With axle and tongue weights available (and Airstream's gross trailer weight rating) you ought to be able to eliminate quite a few TV choices (based on your displeasure with your current TV).
I had no desire for a 3/4T truck, but, were I to do it over I'd have gone for a 1T (Dodges ride stiffly) as I can easily approach GVWR I've learned. What I did want was better fuel mileage and power in all applications than my 1/2T shortbed. A longbed 4-dr Dodge with manual transmission fit the bill for me: great fuel economy, greater work ability, and -- with a bed topper -- 170 cubic feet to sling all the stuff I "might" need in the back.
The truck was also necessary for business purposes, so I might have gone for a Suburban otherwise . . but their fuel economy is lousy by comparison. The 305/555 Cummins makes a superior vehicle solo and towing. Just a leetle hard to park, though.
What a retired guy can use is different from a family man, etc. Same with those who might run the truck 8,000 miles annually versus 28,000 annually (I've been in both positions); the ownership expense becomes higher.
I, too, agree with finding a nicely used TV. Use it a year or so and then decide if a newer one is the way to go. A 3/4T 2004.0 Dodge with the Cummins is at a good price point now, and unlikely to depreciate much the next few years. Stick with 2WD for fewer repairs and maintenance, plus the better ride/handling of IFS + rack & pinion steering. Tires and brakes last forever (Michelin & MOPAR, respectively).
Two engine configs in '04: Be sure it is the 305/555, not the 325/600.
http://www.autotrader.com/dealers/dd...=&cardist=6672
Add a rear axle anti-roll bar [HELWIG], lose the gimpy "running boards", add BILSTEIN blue/yellow shock absorbers, MICHELIN tires, TORKLIFT hitch receiver, tonneau cover or topper, and change the fluids, lamps, etc. This truck can easily get 16-19 in town and 21+ on the road (see sig). I've only had to replace the u-joints on mine (the single repair) in 170,000 miles.
Good luck
Old 09-01-2010, 05:09 PM   #18
2002 30' Classic
Ocala , Florida
3/4 T diesel is the your best choice. It will get you up the mountains and most improtant it will help you slow down going downhill.
We recently spent a month in British Columbia through the Okanagen Valley on up the Ice Fields Parkway to Jasper. I can atest to the fact that if we did not have our F-250 diesel we would be stranded someplace. The tow haul features of the modern diesels are excellent at helping to slow you down on the 6-8% downhill grades. The lugging power of the diesel going up these same grades for 3-4 miles makes for good towing capacity. Don't even consider something less if you want to be safe and capable of handling a 34' AS.
Bigdaddy_2 is offline   Reply With Quote
Old 09-02-2010, 06:16 AM   #19
2007 31' Classic
holland , Pennsylvania
had a 350 gas with a 26 foot sob that weighed 6500lbs and that truck struggled with the hills in pennsylvania.with a 31 or 34 size trailer going into the rockies the best answer from experience is 3/4 ton diesel,or 3/4 ton big block gas motor.however drive both and i think you will prefer the diesel.as far as noise the newer diesels are almost as quiet as gas models.my 2005 6.0 diesel is noisy at idle but quiets down under highway speeds.gas or diesel is going to be loud under load going thru the rockies.
xonvldz is offline   Reply With Quote
Old 09-02-2010, 11:28 AM   #20
1960 22' Safari
Let me suggest a quick rethink on a F350 or F450.
While both of those trucks are great. You may want to consider that those rear suspensions are way more than you need and they are very stiff. That stiffness will transfer to your trailer and beat it pretty bad. Rivets will pop and things will come a loose.
A F250 will have all the pull and stop you will ever need for your trailer and treat your trailer to a more gentle ride which will save you in trailer repairs.
WBCCI 3344 FCU
AIR# 13896
CA 4
Can you tow a 31' with 12 a bhp tow vehicle? goatfarmer Member Introductions 6 06-30-2010 10:40 PM
Do I need a tow vehicle? mimiburt Tow Vehicles 14 05-17-2010 04:11 PM
which tow vehicle? wayne.yl Tow Vehicles 4 01-17-2006 12:06 AM
tow vehicle howardP Tow Vehicles 14 12-11-2004 01:49 PM
tow vehicle Rayconk Tow Vehicles 2 02-15-2003 07:32 AM
