04-08-2022, 12:26 AM
Anchorage
, Alaska
What are opinions on wood over inside skin
I am getting back to a 1963 Bambi project started and set aside several years ago. As I researched work that needed to be done on my Bambi, I was really fascinated by the folks that had used Baltic birch to put a wood interior over the skins. It looked so warm and beautiful
Since I set the Bambi project aside, I’ve made a cedar strip canoe. Learned how to form the strips to the curves of the canoe, have a bunch of material left over, and have started thinking about combining the thinking of the canoe & Bambi projects. (Thinking the long, front-to-back strips would contribute to the illusion of depth to my otherwise small trailer)
But recently I saw another “vintage” trailer with a household wood paneling interior. It looked sooo dated, sooo dark. I could almost smell a musty smell, just by looking at pictures !!!
What are opinions of wood interior skins ? Just because I can, will I regret it ?
04-08-2022, 01:23 AM
Salem
, Oregon
Hi, wood interiors can look great. My concern would be weight. Especially on newer Airstreams which have weight stickers on them. Thus, reducing your payload.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
04-08-2022, 10:53 AM
Nevada City
Check out timeless travel trailers web site. They did a similar trailer in wood strips and copper end caps. It’s the Orvis edition. It’s beautiful.
04-08-2022, 02:23 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
Do whatever delivers the interior you desire. Be sure to use bendable plywood and in the thinnest sheets your local lumberyard can acquire; typically 3/8" is all you need. Inquire as to species available.
Bendable plywood (also known as Curve-Ply, Flexply, Wacky Wood and Wiggle wood, bending plywood) is normally made out of hardwood imported veneers with the grain layers all running in one direction, this allows bend-ability to the panel and can be applied on a curved radius. There are two directions of bend. One is along the width of the panel piece 4' and the other is along the length 8'.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
04-08-2022, 03:59 PM
1994 30' Excella
Mississauga
, Ontario
you can get plywood in 1/8 inch thickness. It is light weight.
Al
Al and Jean
TAC ON-3
04-08-2022, 04:00 PM
1994 30' Excella
Mississauga
, Ontario
I did the interior of mine with cork.
Al
Al and Jean
TAC ON-3
04-09-2022, 09:25 AM
1947 22' Liner
CHARLESTON
, SC
I used heart pine on the floor of my 22’ Liner at 3/8” thick and on the walls 3/16” thick attached to 1/4” thick plywood which replaced the inner aluminum skin. It has been very durable and is beautiful to the eyes. I also used it on the cabinetry. Surprisingly, it weighed in at only 3500 pounds dry. For added warmth and to protect the wood we rubbed it down with tung oil. Turned out beautiful so I highly recommend wood.
04-09-2022, 09:46 AM
2012 23' FB International
Woodstock
, Ontario
I “wood” be worried about weight
Original trailers did not have an aluminum interior skin which in itself is heavy so adding more weight over top. Just means you lose some of the trailer carrying capacity
04-09-2022, 09:52 AM
1953 21' Flying Cloud
Modesto
Check out Fasade flexible PVC panels. They have some amazing products that come in 4 x 8 sheets. Super easy to apply
04-09-2022, 10:28 AM
1993 34' Excella
Estancia
, New Mexico
Can you provide a link please?
04-09-2022, 10:46 AM
Here and There
, West Coast
Originally Posted by Aktundra
I am getting back to a 1963 Bambi project - I was really fascinated by the folks that had used Baltic birch to put a wood interior over the skins. It looked so warm and beautiful
If not the entire interior what about considering portions or just accents in wood? The idea of using the strips has all the ingredients of a really great project!
04-09-2022, 11:17 AM
1964 26' Overlander
Milton
, ON
I did the inside of our '74 Sovereign with wood (1/8" Baltic Birch plywood) and it turned out nice, but it was a lot of work. One drawback is if you have a leak the wood may stain and/or delaminate at that point.
04-09-2022, 02:06 PM
vintage travelers
1972 31' Sovereign
Johnson City
, on the road
1/8 even 1/4 ply
Try 1/8 birch you can clear coat or stain it. If you use 1/4 steam the back of it and it will roll nicely. The first 2 pictures are 1/4 birch streamed to make the roll and stained to a red mahogany. The third is a wall I did with 1/8 birch clear coat only.
04-13-2022, 09:24 AM
33 foot Spartan Royal Man
Guelph
, ontario
Wood interiors
My Spartan(s) isn't (aren't) pristine but still mostly original, Birch and birch ply, and I don't think weight was a problem.
http://desmo.ca/pb/wp_c4226db8/wp_c4226db8.html
Check out some other spartan interiors. www.spartantrailer.com
I love the look and feel, Shellac that can be renewed..
Go for it, lots of ply available and you can replace some of the original panels for weight.. Spartan must have had big steam presses for the curves.. but all panels are removable, even trim on one is held with tiny screws not brads.. !
04-13-2022, 09:25 AM
1972 23' Safari
Houston
Wood over Vinyl
I’ve done 2 72 Airstreams which have that fake plastic on them. I used 1/8” birch and birch Veneer to in some cases cover the existing fake surface.
In some cases I took out the existing panels and replaced and I others used the veneer. There’s a thread I posted on the results. Looks so much better.
04-13-2022, 10:11 AM
1965 26' Overlander
El Prado
, NM
I don't think weight will be an issue. Your talking about an older Bambi. The older Airstreams were designed to be super light. Remember the cyclist towing 9ne. Well little extra weight might provide a bit more stability. I doubt you will add enough to cause any issues. Have fun with your project.
04-13-2022, 10:20 AM
2022 25' Flying Cloud
NCR
, Ontario
IMHO, don't add wood as its will add significant weight.
if this is a static , non-moveable AS, then go ahead
2023 25' FB FC, hatch, Queen, 30A, 1AC, Awning pkg, Convection uwave.
Multiplus 12/3000-50, 700A Lion, MPPT 100/30, Orion-TR 30, Cerbo GX,GX touch 50, Lynx distributor, dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors
NCR , Ontario, VE3HIU since 1978
WBCCI# 21212
04-13-2022, 10:30 AM
1966 30' Sovereign
Wimberley
My floors are cork. Where did you find the cork you used to line the interior skin?
Thank you,
Kim Koogle
1966 30’ Sovereign Airstream
04-13-2022, 10:32 AM
1966 30' Sovereign
Wimberley
Beautiful!
04-13-2022, 10:34 AM
1961 22' Spaceliner
Portland
, Oregon
I would have said hell no, then I saw you were in Alaska and I say HELL NO!
After gutting my '61 and tearing out all the rotten, moldy disgusting wood, I have avoided wood in my trailer as much as possible and what I have is marine grade with an epoxy coat. If I could so it over I would go synthetic.
I painfully scraped the Zolatone and polished my inside skins and they are beautiful IMO. In cold temps we get a ton of condensation which I would think would cause massive rot and mold inside wood paneling.
