I like that!
msspag, that is some solid engineering. I may steal your idea. We have a 2001 Bambi 19 with the same bath and the same complaint, too cramped with the door closed. I am currently replacing the carpet with vinyl so the interior is torn out and I plan to do a toilet mod to address the lack of foot room at the same time.
My toilet (photo attached) is turned slightly toward the rear, apparently with the intent of allowing one to close the door while using the toilet. It doesn't work. I'm not a giant, but at 6 ft. I have to leave the door open and place one foot in the shower and the other outside the door. In your photos it appears that your toilet may be mounted straight ahead, is that correct? I am trying to turn mine either straight ahead or even a bit toward the front. I have removed my toilet and removed the six screws holding the flange to the floor, but can't see how to turn it. Did you have to turn your toilet, and if so, what is the trick? I may make a new thread from this, but maybe you or someone reading your post will have the answer...
