I have had this happen on a few units,
1. spray some dry lock lube into the key hole
2. insert key and "wiggle" while gently trying to turn, and press lightly on the handle to release tension on the lock pawls.
The lock rotates behind to "ramps" on the latch handle, if the door or handle has any pressure against it, the lock cylinder will not turn. I have had 2 of these that I had to drill out-break them to get in and then replace the whole assembly with new.
The units that I keep lubricated well do not have this issue.
