Originally Posted by Tbeck11931
If you know where the main frame runs along both sides there should be jack stand points designated with a diamond shape indicator.
Does anyone really use those?
First, you don't put the jack where it says "Jack", you follow the arrow to a diamond shaped plate. It's supposed to be on the frame.
It requires you to lay on the ground to see them, not a bad deal if you're changing axles, but for tires? Eh? Then my jack isn't flat on top so I need a block of wood also. Then Airstream sometimes runs gas lines or water lines right in the area, just to keep it from being too easy!
I'll venture most folks use the two ramp idea or a floor jack on the axle support rail.
