01-09-2022, 05:19 PM
2021 30RB Classic
Tucson
Lift install
Hi,
We have a 2021 Classic. We'd like to get it lifted. Is this possible?
The Dexter website and all I've found only goes to 2020 models.
Will appreciate any help.
-Arthur
01-09-2022, 05:31 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Originally Posted by turonueve
Hi,
-Arthur
Hi
One would assume that the Dexter site simply has not been updated for a while. A call to JC would be the best way to make sure what you need to do.
01-09-2022, 08:32 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
I’ve done tons of 2021’s. No issues
01-10-2022, 03:57 AM
2017 16' Sport
N/A
, N/A
Given that a single trailer is a ton and a half, are you talking 2 trailers?[emoji846]
01-11-2022, 05:32 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
It's the anti-gravity beam that he uses to lift the trailers that has things mixed up.
01-11-2022, 04:00 PM
Moderator dude
1966 26' Overlander
Phoenix
Hi
I used to have one of those. It slipped away.
Action
01-11-2022, 05:15 PM
2013 31' Classic
billings
, Montana
Hi
Lift kit..3”..
01-12-2022, 12:09 PM
2015 23' FB International
2007 19' International CCD
Steamboat Springs
If you can retrieve the serial number from the sticker on the axles then call Dexter they will tell you what lift kit you need. You could order from Dexter, but I would order from Ronnie and get the bolts with the tabs welded on. Makes it much easier to install.
04-22-2022, 02:53 PM
2021 33FB Classic
Houston
I am interested in lifting my 2021 Classic. I saw your reference to buying the kit from Ronnie to get the bolts with the tabs welded on. Sorry if I just plain missed it, but who is Ronnie and how do I reach him? Thanks!
04-22-2022, 04:10 PM
2022 28' Pottery Barn
¯\_(ツ)_/¯
Find out what axles you have and get the Dexter kit from etrailer.com or anyone else at a decent price.
You can do it yourself with usually little or no modifications depending on your setup underneath, or have any trusted and competent automotive or trailer shop do it.
Lots of threads on here about it.
04-22-2022, 05:38 PM
2022 25' Flying Cloud
Vashon Island
mikesimon,
Here you go:
https://www.airstreamclassifieds.com...alabama-359663
He's on this thread as GMFL
04-22-2022, 06:46 PM
2018 30' Flying Cloud
Springfield
, Ohio
Do get the lift kit from Ronnie - use the like above. Having the tabs welded to the bolts can make all of the difference during the install. His kit is worth the cost!
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
04-23-2022, 11:03 AM
Steamboat Springs
I have now installed lift kits on two Airstreams, a single axle Bambi and a dual axle 23FB.
I would suggest having:
-lift kit from Ronnie, with the tabs welded on the bolts. It cannot be emphasized more on how much work and aggravation this will save you.
-electric impact wrench; this will make it so much easier to loosen up the existing nuts and bolts that hold the axle to the frame.
-hydraulic jack to lower each axle then lift into place once the lift brackets are installed. Note: be sure to loosen both sides before lowering one side to prevent putting stress on the opposite side.
-sufficient safety jacks. I use six (6) positioned on the frame to spread the weight.
-torque wrench to tighten up the bolts and nuts. I think I torqued mine to 145 pounds.
-having a nice concrete floor and good lighting helps!
04-23-2022, 11:04 AM
Steamboat Springs
Or, just schedule with Ronnie and have him do it!
04-23-2022, 01:02 PM
2018 26' Flying Cloud
Fort Calhoun
, NE
Steamy1, that's a great list of items. I did all that was suggested except for the first -- I scored some 2.5" stainless square tubing (1/4" wall) and made my own lift spacers. If you have a angle grinder and a drill press, it doesn't take all that much additional time.
