11-25-2012, 11:57 AM
1974 Argosy 20
Kooskia
, Idaho
BAL jacks and electric drill
I know I have seen some information on powering the BAL stabilizer jacks with a cordless electric drill, but a search has not located it. For anyone who has done that, how did you chuck the socket into the drill? All I can think of is to take a socket extension and cut one end off, and then grind some flats into it so it will be griped by the drill chuck.
Is there an easier way? The steel used on those extensions is hard to cut.
What size socket is going to be needed? I am not at home now and can't just go out and try things.
Thanks in advance.
11-25-2012, 12:02 PM
2008 27' Safari FB SE
Miami
I just bought one at Camping World. Started to tell them what I needed and didn't even need to finish the sentence before they handed me to tool. Basically a socket welded to a 3/8" shaft. Works great.
Mike
11-25-2012, 12:21 PM
1995 30' Excella
Bowie
, Maryland
You can also get them at Amazon.
We have one, but we don't use it that often - just not worth the trouble.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
11-25-2012, 12:26 PM
2019 27' Flying Cloud
Albuquerque
, New Mexico
Camping World Item
Ultra Speed Socket
Catalog Item # 34587
This Item is In-Stock and Ready to Ship
Internet SALE
$8.99 SAVE $1.00
Reg $9.99
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
11-25-2012, 12:42 PM
St. Cloud
Go to Home Depot or homedepot.com. Search for a 'steel square socket adapter' -- just under $4. You probably want the 1/2". It should fit the 3/4" spark plug socket in any socket set. That's what works with your BAL jacks.
11-25-2012, 01:25 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
1/4",3/8" and 1/2" will come in handy for the AS tool kit.
11-25-2012, 01:42 PM
Oswego
If you use what Robert and Canoestream suggest, the 3/4" socket can do double duty for the wheel lug nuts as well as the Hensley jacks (and PP too, I think).
-Rich-
11-25-2012, 02:05 PM
1974 Argosy 20
Kooskia
, Idaho
thanks guys, I didn't know those little drill to socket adaptors were available. I have lots of sockets, so that is the easy solution.
You see, I just got a new Ridgid Lithium 1/2" drill at Home Depot on Black Friday sale. Great drill, amazing unconditional lifetime warantee, even on the battery! Only $100
Now I have to find some good uses for it. Grin
11-25-2012, 02:32 PM
Albuquerque
, New Mexico
Safety Note
Until you get used to it, hold the drill with both hands, and crank the jacks at low speed.
You can sprain a wrist or even a shoulder if you aren't careful.
Don't ask me how I know this.
11-25-2012, 02:38 PM
1981 27' Excella II
mays landing
, South Jersey
I know I know how you know this. Don't ask me how I know I know. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
11-25-2012, 03:16 PM
2007 23' International CCD
Rocky Mount
, Virginia
My chin knows how I know.
11-25-2012, 03:17 PM
1985 31' Limited
Nellysford
, Virginia
Bal
I use an impact drill that I use to take off and replace lug nuts. Just use an extension and a socket and you are good to go. Carry it with me as well as a cordless drill.
I have an Avion and the crank shaft for the jacks is further under the trailer than it is on the AS and hence the need for the extension.
Ron T
Avion 34W, 1987
11-25-2012, 04:25 PM
Antiquepedaler
2010 25' FB Flying Cloud
Laramie
, Wyoming
Thanks in advance.
Ace Hardware. Tell them what you want to do. Socket size is 3/4" 6 point.
Antique Pedaler
2021 Caravel 20 FB
11-25-2012, 04:29 PM
1976 31' Sovereign
Oswego
I have used cordless drill with socket and adapter for many years, just remember to charge drill before using or else take charger with.
11-25-2012, 04:31 PM
Livingston
Idroba, also if you have the type of drill with a torque setting, use it. They can produce a lot of torque. I use a 14 -16 setting on my drill (Milwaulee 18 volt) and it puts just enough onto the jack with out "lifting" my AS incorrectly.
Sphere Guy
AIR 50601
11-25-2012, 05:19 PM
1974 Argosy 20
Kooskia
, Idaho
Thanks for that tip, my drill does have a torque setting, and it is a very powerful 18 volt Ridgid, so it could throw one I am sure. I had not thought about using the torque limiting feature for the application of running the stabilizing jacks.
Good call.
11-25-2012, 05:30 PM
Ludowici
, Georgia
I use a cordless impack wrench to lower my jacks.
04-22-2013, 06:14 PM
1979 31' Excella 500
1973 25' Tradewind
Cinnaminson
, New Jersey
Harbor Freight has inexpensive socket adapters.
I use an 18v HF cordless drill, 74 ft/lbs, that sometimes is not enought torque, or maybe it needs a bit more lubrication on the threads.
Tom Beitz
6760 PA Unit
TAC NJ-5
Riverton, NJ
04-22-2013, 07:15 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
No grease/oil....
....... dirt and grime is attracted to grease/oil on the BAL screws, I just keep them clean, If you need to lube use a dry graphite lube.
04-23-2013, 05:37 AM
1995 30' Excella
Bowie
, Maryland
Yeah, do not grease them. Ours have gotten to the point where they pretty hard to use, and I think the grease made them worse, not better. I've been trying to graphite lube them, and it is helping, fortunately.
