04-19-2018, 03:53 PM
#21
2016 23' Flying Cloud
Corpus Christi
AC rocking from side to side
Thank you all for all the suggestions.
04-19-2018, 05:25 PM
#22
2015 16' Sport
Kodiak
, Alaska
Originally Posted by tjdonahoe
No.....level trailer....then drop the stabilizers down plus 1 turn...helps keep it from rocking
Right. I've not used mine for leveling and thought it odd that the previous post mentioned using them in that way.
04-19-2018, 05:46 PM
#23
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Me also from TX, I know the issue can be caused by some of us guys having a bit of a buba issue out front...I know my weight can sway the trailer unless I have stabilizers good and solid on ground...just saying ....I use the Ryobi cordless drill with the adaptor socket to lower/retract my stabilizers. Much faster and easier. I use 2 hands and take it slow, because the torque can "get ya" if your not careful...I also use the "X-Chock" scissor type tire stabilizers between the tires, which help alot.
Another cure could be a larger AS? :-)
04-19-2018, 07:10 PM
#24
2019 25' International
Washington
, Washington, D.C.
And don't forget to raise them first thing when you break camp. (Add as #1 to top of your checklist).
04-19-2018, 07:28 PM
#25
2007 23' Safari SE
Annandale
, New Jersey
Get an extra set of leveling blocks you would use under the tires to level the AS and put one under each stabilizer, almost eliminates the settling into dirt, gravel or sand. Its also always nice to have an extra set incase you get one of those ... sites.
04-19-2018, 08:52 PM
#26
2013 25' FB Flying Cloud
Scotts Valley
Originally Posted by rucos
You may want to consider aftermarket cross bracing systems that will greatly increase your stability after the jacks are down.
Can you please elaborate on what aftermarket cross bracing systems means? Is this the same as X-chock between the wheels, or something different?
04-19-2018, 09:43 PM
#27
2018 30' International
Prescott
You’re camping
Glamping
RV’ing....
It’s a vehicle. It’s going to move.
Enjoy it it’s part of the experience.
Outside of a dog, a book is mans best friend. Inside a dog, it’s too dark to read.
04-19-2018, 11:38 PM
#28
Len and Jeanne
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley
, British Columbia
This is basically what we do. We travel with a bunch of those flat square plastic risers designed to go under the low-side tire. When camping on a soft surface like sand or wet soil, we put one under each stabilizer, as well.
04-20-2018, 12:43 AM
#29
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Yup, we use plastic ramps for leveling and the plastic Lynx Blocks under stabilizers, and under the jack. If the slope is too severe for ramps, we also build platforms out of Lynx blocks and back the trailer up onto those.
We do not use wood blocks / ramps under the trailer for several reasons: (1) they are heavy (2) they get dirty and wet and are hard to clean (3) we worry they will draw bugs as they age (4) splinters, and (5) we just don't like them.
04-20-2018, 06:05 AM
#30
Registered User
2016 25' Flying Cloud
Fairfield
In California, we leave the stabilizers up. It smooths out the earthquakes. [emoji23]
04-21-2018, 12:48 PM
#31
1972 29' Ambassador
Boynton Beach
Well played, sir!
04-22-2018, 07:24 AM
#32
Silver Star
1970 23' Safari
Victoria
, British Columbia
What Ive looked at but haven't installed yet is a cross bracing system that helps stop sideways movement. Wheel chocks help back and forth but not the sideways rocking. One product is made by Winfield RV.
Google "cross bracing stabilizing jacks for RV " and you 'll see several options that make sense.
04-22-2018, 12:14 PM
#33
Sag Harbor
, New York
I can't imagine that the OP -- with a FC23 similar in length -- needs that level of cross-bracing for such a short trailer. The motion of the trailer moving when someone else walks in it is part of the romance of RV'ing IMO.
Like a boat rocking gently on the waves . . .
Expecting a rock-solid sleeping experience may be an expectation worthy of reconsideration.
http://winfieldrvproducts.com/scisso...tabilizer.html
04-22-2018, 02:57 PM
#34
Green Cove Springs
Camping in a tent will provide a rock-steady floor, though.
04-22-2018, 06:11 PM
#35
East Falmouth
, Massachusetts
Motion
Step one
Air pressure in tires
04-22-2018, 06:49 PM
#36
2007 22' International CCD
Corona
Must have auto-corrected. I think it should be “rock-strewn” floor? At least that’s MY experience...[emoji3]
04-22-2018, 07:03 PM
#37
Sag Harbor
, New York
. . . still "steady" nonetheless!
04-22-2018, 11:41 PM
#38
Corona
Yup. That’s why I’m camping in an Airstream with a more comfortable bed than when I was a long-time Boy Scout Adult Leader.
Went some really beautiful places, but nowadays I need more padding to sleep well.
04-24-2018, 08:02 AM
#39
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Some of us, unfortunately, have added additional padding to our bodies over the years.
04-24-2018, 08:03 AM
#40
2015 27' FB International
Wheatley
, Ontario
Originally Posted by kc5me
lol lol lol
