04-23-2021, 06:26 PM
1968 28' Ambassador
Ames
, Iowa
Airstream window shattered on cross country trip
Hello all,
My husband and I are on our first cross-country trip (Iowa to Moab, Utah) with our ‘68 Ambassador. Last night, the front and side window shattered when we hit a major pothole. Is this something that an auto glass repair shop could fix easily? Right now we have it rigged with a ton of duck tape, but it’s an eye sore and definitely not safe. In the meantime, if you have any good ideas of how to secure the windows, please let me know!!
Thanks in advance!
04-23-2021, 07:10 PM
2004 28' Classic
Monument
I recommend going to a Home Depot and picking up a Lexan sheet to cover each window. Cut it to size. Hold it in place with Gorilla tape on the edges. Replace it when you get home at your AS dealer.
Good luck and enjoy your trip!
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
1966 22' Safari
Fredericksburg
It’s thin tempered glass. You may want to consider going by one of the big box stores and have them cut you a couple of pieces of plexiglass the exact size as replacements that you can temporarily install until you get back home. Not sure if an auto glass shop has that type of glass in stock. We have a 66 and the flat glass windows have the aluminum strips holding the glass in place with glazing tape. That must have been a heckofa pothole to cause that much of a percussion. Good luck
04-23-2021, 07:12 PM
2004 28' Classic
Monument
Where are you right now?? If you are close by to Monument CO, I'll help you fix it.
DaveP
2023 Ram 3500 4x4
1966 22' Safari
Fredericksburg
Not that I’m a great mind, but some great minds think alike.
04-23-2021, 07:16 PM
2004 28' Classic
Monument
Agree!
Agree!
DaveP
2023 Ram 3500 4x4
04-24-2021, 05:02 AM
Sag Harbor
, New York
Welcome to the forum . . . sorry for your baptism by fire. Are you close to Dave in Monument, Colorado, by any chance?
A very generous offer . . . thank you . . .
04-24-2021, 09:18 AM
1976 Argosy 26
Los Altos
Happened to me last summer
Duck tape held mine in place from southern New Mexico to SF nay area to Las Vegas where we had it fixed. Definitely let Airstream techs do it. More complicated for vintage trailers.
04-24-2021, 10:39 AM
2016 30' Classic
2009 25' FB Flying Cloud
Dade City
Shattered window
We had similar problem in Canada and a fellow at Ace Hardware cut us a lexan piece which he taped on and lasted us back home with no problems. Only charged us $20.
04-24-2021, 01:34 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
The last time I hit a bad pot hole the rear end separated, but no glass broke. However, a while back I had a frame that was found to be cracked. The Airstream Factory Service Center welded it for me. This history is offered so you can look over these items to see if you experienced any of them. Some are not obvious on a walk around like a broken window.
guskmg
04-24-2021, 01:42 PM
1994 30' Excella
Livingston
Window Replacement
In 22 years of Airstream Ownership, I had two broken windows. Both times occurred while boondocking in the middle of nowhere. Both were caused by Guests who did not use both hands (despite being briefed) to raise or lower the windows using both window arms. After the first window broke, I now carry a small piece of blue insulation board in the truck topper that I can cut down to size and duck tape into the window frame as a temporary fix. We now have a new window rule for guests... ONLY I CAN raise or lower a window. Just ask! ...you should take it to a dealer for replacement... just bring plenty of $$$$. After the first time it happens to you... you'll understand....
SPCLKAZ
94 30" Excella
99 GMC 3/4 Ton 6.0L
04-24-2021, 04:11 PM
1993 21' Sovereign
Lewisburg
, West Virginia
Same Experience
Enroute the Dallas, the front window on our AS shattered. We called the Dallas Airstream dealer who told us it would take weeks to get a replacement and would cost about $2,000. We found a plastic fabricator in Dallas who would cut the plastic (Luxan - supposedly the strongest), but wouldn't install it. We found a mobile window installer who agreed to meet us in the parking lot of the fabricator and install it. The whole cost was about $400. Insurance would have paid, but it wasn't much more than our deductible.
Good luck.
04-24-2021, 04:15 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Front window is flat glass and can be fixed with glass or plexiglass. The side, I suspect is curved glass. The curved glass is much harder to come by but you can temporally place plexiglass in the slot but you will not be able to open it most likely. The patch will get you through the trip. Hope the rest of the trip goes well.
