Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 08-05-2020, 12:14 PM   #21
2012 30' Flying Cloud
Morongo Valley , California
Originally Posted by Hiho Silver View Post
We keep the Bdrm TV unplugged when not using!!
This is what we do also. Simple!
Alan 117 is offline   Reply With Quote
Old 08-05-2020, 12:42 PM   #22
1990 32' Land Yacht
Lucan , Ontario
You should be able to go into the tv settings and change the remote frequencies so they are not the same for both TVs.
camp-n-family is offline   Reply With Quote
Old 08-05-2020, 01:18 PM   #23
Grace the Airstream
2020 27' Globetrotter
Definitely a first world problem type thing but we got annoyed enough at it and the TV in the main part of the Globetrotter not being a Smart TV, that we upgraded to a Samsung Q50 and moved the living room TV to the bedroom. Now no issue with remotes and we can watch Netflix and Amazon directly on the TV without plugging in the iPad.
Nothing like a few hundred dollar solution to a simple problem
pdavey is offline   Reply With Quote
Old 08-05-2020, 01:52 PM   #24
rr49
Annapolis , Maryland
Our easy fix. Do not point remote control toward TV; rather, point remote to Side wall nearest TV. Signal will not bounce to other tv. Give it a try.
rr49 is offline   Reply With Quote
Old 08-05-2020, 02:22 PM   #25
Grace the Airstream
Originally Posted by Baby Zeppelin View Post
We ran with it unplugged for a couple of years, then finally removed it and put a fan on that nifty mount. Never watched TV from bed anyway, and the fan is nice.
Attachment 374988
Since you posted your fan picture I just have to +1 having those fans in the bedroom.
We installed one on both sides of the bed and tied it into the 12v line.
Old 08-05-2020, 02:35 PM   #26
BS36022
2018 25' International
Clanton , Alabama
I had the same issue. My solution was to unplug the bedroom tv - simple, but effective since I never watch tv in bed anyway. 👍
BS36022 is offline   Reply With Quote
Old 08-05-2020, 02:55 PM   #27
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
pdavey, nice installation on the fans. We think it is one of our best additions to our Airstream. They provide way more comfort than we anticipated. Jim
Jim Flower is offline   Reply With Quote
Old 08-05-2020, 03:12 PM   #28
Lansdale , Pennsylvania
Same issue
We have the same issue in our 2019 GT. Only a problem when watching tv in the living area so I end up unplugging the TV in the bedroom area. Not a significant inconvenience as you don’t loose programmed channels. Easiest solution for me.
BobBee is offline   Reply With Quote
Old 08-17-2020, 10:38 AM   #29
Pace , Florida
Attachment 375003
Part number and installation instructions on the fans? (27FB Flying Cloud)
Thanks!
Rob
Hart_Rod is offline   Reply With Quote
Old 08-17-2020, 10:40 AM   #30
Pace , Florida
Do tell!? Haven't seen anything like that in the settings...
Old 08-17-2020, 11:02 PM   #31
2019 27' Flying Cloud
Box Elder , South Dakota
I want to know about the fans too!
(And yes, both of our TVs turn on or off with one click.)
2019 Flying Cloud 27fb twin
Full-timing with one husband, one cat.
SnooMc is offline   Reply With Quote
Old 08-17-2020, 11:30 PM   #32
SilverWind's Avatar
2022 20' Basecamp
1968 17' Caravel
Los Osos , California
........or just simply give the bedroom TV to a friend.
SilverWind is offline   Reply With Quote
Old 08-18-2020, 07:51 AM   #33
Ready-to-Travel
pmclemore's Avatar
Walkerton , Virginia
A post-it note covering the IR sensor on the TV you're not using will work.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 08-18-2020, 08:07 AM   #34
2020 30' International
Ingleside , Illinois
We had the same problem. However pointing the remote at the side wall does work!
JohnandDonna is offline   Reply With Quote
Old 08-18-2020, 08:12 AM   #35
Grace the Airstream
Sorry for the delay on the fan information folks.
This is one of the best fans out there. Super quiet and moves a bunch of air.
Sirocco II Fan from Seekr by Caframo. 12V /24V DC. Gimbal Fan for Boat or RV. White, 3.5 x 9.5 x 12 inches by Amazon.com Learn more:**https://www.amazon.com/dp/B01LDY4TE4..._r39oFbPTQ258Z
To install I opened up the compartments on the side in the overhead shelf in the front of the Globetrotter.
I tested multiple sets of wires until I found an unused 12v then used that as the basis to install. (You could also tap into another set of existing wires if needed). The source/live wire was on the left side of the cabinet in my unit.
Drilled a small hole in the cabinet to thread the wire through. Mounted the bracket, wired the fan and then installed the set screw.
Super simple upgrade.
There is also a spare set of wires that were not hooked to anything that ran to the other side of the cabinet I used to power the other one but just as easily could have run my own wires with a fish line.
One thing of note is these fans need to be wired correctly with + and - to work so double check with a voltage meter to determine which of the wires you are tapping into are + and -Click image for larger version
ID:	376173Click image for larger version
Tips for removing both wheels to replace both tires chaeha 2005 and newer - Bambi all models 27 12-31-2021 08:11 PM
click click click is all I hear! ericjan2 Electrical - Systems, Generators, Batteries & Solar 10 07-20-2013 09:29 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
click click kepko Generators & Solar Power 0 05-29-2009 12:54 PM
Mounting televisions DrPlay Audio, Video & TV 7 02-14-2008 08:30 PM
