Old 09-19-2020, 06:26 AM   #1
2018 30' Classic
Traverse City , Michigan
Tank Heaters Draining Bettery
We’re in NY with freeIng temperatures. Ran the tank heaters during the night and water pump some this morning. We’re plugged in yet the battery is in the yellow zone and if the pump runs it drops to red. Is that normal?
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
SMKovalchik is offline   Reply With Quote
Old 09-19-2020, 07:23 AM   #2
"Cloudsplitter"
We don't have tank heaters, but it sounds like the converter/charger isn't working. The battery should stay charged when plugged in.
Ck the use/store switch and breakers. Test the batteries, make sure they haven't been damaged.
Where in NY? Here in WNY it was cool but nowhere near freezing. Watertown was 38* last night.
Old 09-19-2020, 08:13 AM   #3
2018 30' Classic
We were in Cuba last night headed to Glens Falls to visit family. I think you’re right. We didn’t have the inverter on.
2018 30’ Classic
Old 09-19-2020, 09:57 AM   #4
Rich W's Avatar
I'm In , Kentucky
The converter (not inverter) is on if you're plugged into shore power. However, in some models, unless you have the Use/Store switch in the USE position, it won't charge the batteries.
Inverter-Convert 12 VDC to 120 AC
Converter-Provide 12 VDC to the Airstream for lights and other 12 VDC devices when plugged into shore power. Optionally, charge the batteries if in USE position (on some models, other models will charge batteries when on shore power. It varies with newer models or owner modification.)
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 09-21-2020, 05:34 PM   #5
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
If the converter is unplugged, or the AC circuit breaker is tripped, or the converter output fuses are blown you will have this condition. Check all three items and see if you can restore power. I have had bad batteries blow the converter output fuses. New batteries and fuses and everything works.
guskmg
Old 09-22-2020, 04:43 AM   #6
2018 30' Classic
Thank you to those who offered suggestions and yes, it was the Converter breaker. Didn’t seem to be a reason for it to flip but it did. All is well with that now. Good thing too. It is terribly cold for this time of year. Fortunately it starts warming up today. Now if someone could fix the Alde system. Alas, not sure that will ever happen.
Again, thank you to everyone.
2018 30’ Classic
Old 09-22-2020, 06:24 AM   #7
"Cloudsplitter"
Glad you're warm again. We are on Lake Erie 20m south of Buffalo...lake keeps us warm this time of year.
Stream Happy
Heaters, heaters, heaters. doorgunner Furnaces, Heaters, Fireplaces & Air Conditioning 80 12-02-2013 10:20 AM
Draining Fresh Water Tank psundstrom Fresh Water Systems 2 10-15-2007 07:37 PM
New member- Water Tank Not Draining jvandal Fresh Water Systems 6 11-10-2006 11:17 AM
Water Tank Draining trippy 2005 - 2010 Safari 1 09-13-2006 07:31 PM
Shakedown trip--holding tank draining quest. Kistler Our Community 6 12-01-2002 09:21 AM
