Originally Posted by Boxite
-- snip -- Use an IR to see if connections or bearings are significantly hotter than their counterparts. That's all there is to it.
Well, maybe ......
However, it might be possible that a higher amperage connection will be hotter than similar connections with lower loads, because for the same contact area, more amperage flow generates more resistance and therefore more heat.
You are correct to maintain that if the temperature is SIGNIFICANTLY hotter, there is a problem.
However, the prevailing use of an IR camera is to identify a problem before it progresses to failure. In other words, it is a preventive maintenance tool. Consequently, there is a need for temperature image analysis skills. It is not enough to simply look for the failure condition as that makes for a really bad day.
So, take care. There really is a bit more to it. Pat
