Old 09-20-2002, 07:28 AM   #1
Question Extra wire
I am Sue martin of Prunedale CA, I have a 67 Caravel "Little Duke" that is about to hit the road. In the wiring of the tow plug my husband came up with a black wire he just can't figure out. All the lights are acounted for, the electric brakes and original converter works. Any ideas what the black wire might be for?
susan martin is offline   Reply With Quote
Old 09-20-2002, 08:13 AM   #2
LOST , Hawaii
Ground?
Old 09-20-2002, 12:43 PM   #3
The black wire is the "back up light" circuit. You can add them if you wish.
inlandrv.com
airstreamparts.com
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-21-2002, 07:52 AM   #4
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Yes, Backup light wiring. I found that wire, rolled up and masking taped to the inside of the exterior wall behind my tub surround just below the rear taillights when I redid the floor on my '65 Globetrotter.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
loose wire whistler Electrical - Systems, Generators, Batteries & Solar 6 02-21-2004 03:50 PM
silver wire? markus Electrical - Systems, Generators, Batteries & Solar 3 12-21-2003 01:19 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
Replacing wire harness Les Gilliam Batteries, Univolts, Converters & Inverters 4 08-19-2002 08:25 PM
HOT Topic for the summer-Air conditioners-Best/worst? thenewkid64 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-03-2002 04:55 AM
