. . . and you should wait an hour or so, after you stop charging the battery, to measure the voltage.
FYI this Battery School is a good resource for learning more about RV batteries:
http://www.batteriesnorthwest.com/ba...cfm?TID=1#ANC1
The list of voltage levels is important to keep in mind . . . that you should not allow a regular wet cell battery go below 12.2 volts [50%], or you risk damaging it.
Your Airstream owner's manual should also have a decent write-up on the voltage monitor, and on general battery maintenance.
Happy New Year,
