Old 03-25-2020, 09:49 AM   #1
2017 19' International
Tallahassee , Florida
Batteries — how much water is too much?
Checked the water level on my two Interstate flooded batteries this morning, and they looked good ... I think.
But ... where should the water level top off?
How much water is too much?
WhereStream is offline   Reply With Quote
Old 03-25-2020, 10:04 AM   #2
Retired.
. , At Large
The water level should be between the ring at the bottom of the vent and the top of the lead plates. If you're filling, the water needs to cover the top of the plates.
Old 03-25-2020, 10:40 AM   #3
2019 25' Flying Cloud
Hendersonville , North Carolina
Watering Battery
When you add water to the battery use only "Distilled Water" not regular tap water. Available at the store in gallon container for under $1.00.
The wife may already have some if she does any ironing. Most irons recommend using only distilled water. Happy travels.
uraljohn is offline   Reply With Quote
Old 03-25-2020, 11:10 AM   #4
Mollysdad's Avatar
The plates need to be covered.
I only used distilled water, and add until the water distorts in the "ring" below the filler cap.
I keep a turkey baster just for water.
Old 03-25-2020, 11:25 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Turkey baster is a great idea. Easier to refill than my squirt bottle.
Old 03-26-2020, 02:02 AM   #6
Sag Harbor , New York
Does your owner's manual not "cover" this?
This Battery School site is a great resource:
http://www.batteriesnorthwest.com/batteryschool.cfm
Please note cautions . . . like . . . fill water only after recharging.
You should wear gloves and safety goggles when filling the batteries, and yes a turkey baster works great.
A fowl idea?
Peter
Old 03-26-2020, 07:53 AM   #7
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
This is exactly what I do, fill until I see the water level distort. I use my EZ-Red Hydrometer instead of a turkey baster. The EZ-Red Hydrometer is also useful to test condition of your batteries: https://www.amazon.com/dp/B000JFHMRU..._t1_B0050SFVHO
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 03-26-2020, 10:03 AM   #8
Thanks, everyone.
The “distorts the bubble” is great advice.
Currently, water covers the plates but does not quite touch the little site tube.
That seems good enough for now, as I have only tap water to add.
Distilled water doesn’t cross the “vital need” threshold, so not making a run to the grocery and mixing it up with all the frantic folks there.
Is this question addressed in the owner’s manual?
Don’t know. Extracting info from the manual can be a time-consuming process sometimes.
Easier and more fun to ask here.
If that’s an Airforums faux pas, please let me know.
Old 03-26-2020, 11:56 AM   #9
2012 23' FB International
Woodstock , Ontario
The batteries usually come with enough acid to cover the plates..seldom up to the ring. That being said, the original acid concentration can handle dilution water up to the ring. The charging replenishes the acid concentration. Running with acid above the plates is perfectly acceptable till you get the distilled water. Try to find real distilled water, not steam distilled water... which used to be the only available type. Steam distilled water still has some salts contamination.
JCW
JCWDCW is offline   Reply With Quote
Old 03-26-2020, 12:50 PM   #10
AirMiles's Avatar
Technically, you are supposed to put the water level 1/8" below the plastic that distorts the water. But its really hard to judge when you are 1/8" below the plastic. Therefore, I just fill until I see the distortion. Here is Trojan's excellent "Battery Maintenance Guide": https://www.trojanbattery.com/tech-s...y-maintenance/
Old 03-26-2020, 01:13 PM   #11
Tom T
Tom_T's Avatar
Orange , California
Use caution -
The distilled water only needs to cover the plates, so don't overfill up to the fill ring bottoms - the level should be below, because water expands when hot. If it should overflow or boil-over with heat (normal operating heat or from a short or other electrical system problem), then you'll have acid water all over the place.
That said - I'm using AGM which require no filling & can't boil over, & others are using dry cell or Lithium (LiPo, etc.) which also can't boil over, but Lithium has other cautions.
Many battery & parts etc. shops sell Odyssey dry cell - which are also lighter than wet cell or AGM - as are Lithium. Interstate & Optima & other battery/parts shops now sell deep cycle AGM - i.e.: Absorbant Glass Mat - with gel instead of water for electrolyte, which weigh a tad less than water cell ones.
Cheers!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-22 Cayenne S, EH, etc
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
Tom_T is offline   Reply With Quote
Old 03-26-2020, 01:25 PM   #12
AirMiles's Avatar
I'm certain that overfilling a wet-cell battery by 1/8" will not be a problem. I live in the Tampa Florida area where my battery operates at over 100 degrees every day, I regularly see 120 degrees in mid-afternoon. I overfill my battery by 1/8", until water distorts, in the afternoon when the battery is fully charged. I have never had a problem with the battery spilling over from overfilling. I check my battery frequently and the water level is never higher than distorted. The water level typically settles down to under the plastic by the time I'm done filling all the cells. I do not worry about overflowing my 1/8" overfilled battery.
Old 03-27-2020, 08:31 AM   #13
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
The ring distortion was placed there on purpose, to indicate the fill level.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
How much water pressure is too much? Dreamnair Fresh Water Systems 10 09-17-2009 06:16 AM
how much wind is too much Barry Parkof Awnings 15 04-04-2009 12:19 PM
How much is too much, or too little - 1962 Globetrotter? gduffydc 1960 - 1964 Globetrotter 3 01-07-2009 02:39 PM
How much damage is too much? kaulike Ribs, Skins & Rivets 8 01-20-2007 01:10 AM
Carbon Monoxide: How much is too much? Lotek General Appliance Topics 3 01-08-2005 06:06 AM
