12-14-2017, 09:36 PM
2018 30' Flying Cloud
brooklyn
, New York
Something's up with our Solar (?)
Scenario;
320 watts of solar on a 30 foot bunk.
Have used it from NYS to New Mexico from Sept to Dec.
Used to charge fine meaning we felt like we were always at 100%
Today we were at 80% and left the trailer at 11:00am.
We have full unobstructed New Mexico sun (dec 14).
We left with nothing running and all lights off. (We're fully dry camping right now).
When we arrived back at 8:30pm we thought for sure we would be at 100% but we were actually down to 60%!
We can't seem to figure it out. (Pump was 'on' but not running, no lights, no heat, inverter off, fridge on gas...)
We're totally new at this. Any advice appreciated!
Joe
12-14-2017, 10:29 PM
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Perhaps a silly question, but the first thing I would have done is checked my monitor to see if the panels were working? Did you?
12-14-2017, 10:30 PM
brooklyn
, New York
Yeah, they were at 45% when we woke up and had been climbing all morning.
12-14-2017, 10:41 PM
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
OK. Not quite understanding. 45% of what. Do you not have a way of reading what voltage or amperage is being produced by your panels? What is normal output. What do you have for a charging unit or battery monitor?
12-15-2017, 04:51 AM
2014 25' FB Flying Cloud
2005 30' Classic
Keswick
, Virginia
How old are the batteries? Check those. Are they sealed or unsealed?
Greg
2014 25' Flying Cloud FB
2015 GMC Sierra Denali 6.6L diesel
Charlottesville, Virginia
12-15-2017, 05:27 AM
Lakes Region
, New Hampshire
As gandttimes suggests, check to be sure that your monitor panel indicates that there is power/charge coming out of the panels (not what your battery is reading) the fact that you are down to 45% or lower means you're batteries are now starting to suffer damage also. Usually one of the buttons on the display allows you to toggle through the different functions, you are looking for one that indicates "charge out (or in)"
After that, there would be a shutoff switch and circuit Interrupters between the panels and system that you would check if the display indicates zero out.
12-15-2017, 07:32 AM
2011 27' FB Classic
Camp Hill
, Pennsylvania
I had a similar problem. Check to see if the lights are on in your outside lockers. Also the refrigerator eats quite a bit of battery on hot days.
12-15-2017, 07:40 AM
2007 31' Classic
Gulf Breeze
Run the fridge on Propane...not battery.
12-15-2017, 07:41 AM
2007 31' Classic
Gulf Breeze
Are your fantastic fans on thermostat?
12-15-2017, 08:18 AM
brooklyn
, New York
Thanks everyone;
My sunexplorer display panel reads;
35 Battery Percent Remaining
11.5 battery voltage
11.5 solar voltage
.6 solar charge amps
64.2 solar amp hours
(Charging status is red)
This is 8am with no direct sun and after the furnace running for much of the night.
(Bin lights off)
(All fans off)
12-15-2017, 08:26 AM
brooklyn
, New York
Originally Posted by megadice
Thanks everyone;
11.5 solar voltage
(Bin lights off)
(All fans off)
Oh yeah, brand new sealed batteries.
2018 flying cloud.
12-15-2017, 08:32 AM
2002 30' Classic S/O
Fleming Island
How are your panels configured? Are there blocking or bypass diodes in your junction box?
Data from a full sun environment would be more instructive. When was the last reset of the solar amp hours statistic?
Check your fridge for a "Climate Control" switch. It should be OFF. This runs heat strips in the door frame to control condensation. Also the low ambient switch, if you have one, should be OFF. This runs the light in the fridge all the time to increase run time.
It sounds like you have a significant phantom draw which could be in your trailer or a failure of the solar charge controller.
Al
12-15-2017, 10:19 AM
2017 30' Flying Cloud
Spotsylvania
, Virginia
The refrig. uses 12 volts while it is running on propane.
12-15-2017, 10:40 AM
Oswego
Very little...much less than 1A, unless a cooling fan(s) are installed, in which case mine draws a bit over 1A.
-Rich-
12-15-2017, 01:32 PM
1977 Argosy 28
Euless
Are the solar panels clean? Mine get covered with dirt and tree sap and my output drops noticeably. Wash them with soap and water or Windex. Also, the sun is at a lower angle this time of year, so, unless you can tilt your panels toward the Sun your output will be reduced.
Past President, Vintage Airstream Club, WBCCI # 7291
1977 Argosy 28 Center Bath (CA made) and 2015 Ford F250 6.7 diesel. Used to own 1978 Argosy Minuet 6.0 and 2013 Toyota Tundra
12-15-2017, 04:03 PM
NOAZRK
2004 34' Classic S/O
Kutztown
, Pennsylvania
Furnace fan, refrigerator, minor lighting, perhaps a radio accidently left on, check battery water level, check closet light switch(s) working plus anything else you can think of.
12-15-2017, 04:23 PM
Hollidaysburg
, Pennsylvania
Solar charge fuses
Check your charge fuses. In our 30 Classic, they’re beneath the wardrobe. 20 amp. Faulty electric or a surge blows them every time.
12-15-2017, 04:27 PM
2015 30' Classic
Pleasanton
I'm with RVB's point regarding the sun - it is mid-December!
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
12-15-2017, 04:37 PM
2016 27' Flying Cloud
Hartsburg
, Missouri
As suggested by others your panels will not work as well in December because of the lower angel of the sun. Nevertheless get a reading of your solar voltage and amps at midday with the panels unobstructed to see how they are performing. Irregardless of the panel performance something was drawing your battery down. However, first order of business is to not draw down the batteries further and find some other way get them fully charged ASAP to minimize damage to them.--Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
12-15-2017, 05:11 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Originally Posted by fran&frank
... However, first order of business is to not draw down the batteries further and find some other way get them fully charged ASAP to minimize damage to them.
It sounds like your furnace running drained your batteries. It draws about 8 amps per hour. Use your booster cables from your runnning TV to add a lot of amps to your house batteries quickly. Many TV with a tow package have 160 amp (or larger) alternators.
Ray B.
