Old 03-10-2003, 12:24 PM   #1
1994 30' Excella
New Smyrna Beach , Florida
onan troubleshooting help
I have an Onan microlite 2800 watt mounted in an enclosurer in the back of my pickup. I use it for shore power when boondocking with the AS. I do run it at least monthly with a load on it as Onan strongly recommends running it at least monthly to avoid problems. I was doing my monthly with the Onan connected to my Bambi and about 45 minutes into the running the ONan got to running rough and quickly died. I now can only keep it running by holding down the toggle switch to the on position. When I release the switch, the generator dies. "Ask Onan" web site just offers little help except to say bring it to a dealer. At $85/hr rate, I would like to attempt to troubleshoot the problem with the help of this member board. Could anyone help me with a troubleshooting process to determine the problem. I am somewhat literate with electricity and can use a meter to check current flow, continuity etc. Any and all help would be greatly appreciated.
Thank You,
Bob Caldwell
rcaldwel is offline   Reply With Quote
Old 03-10-2003, 03:01 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
bad gas?
is your gasoline old?
(assuming it is not a propane powered unit)
next, how old is the fuel filter?
also, does it have a low oil switch? some of the kawasaki's we have at work will quit running if they are only a 1/4 cup low on oil. or do not have them perfectly level.
john
Old 03-10-2003, 05:00 PM   #3
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
i would venture you have low oil . check your oil and verify it is up to where it should be. lol
al
wb13798 is offline   Reply With Quote
Replacing Onan for a portable generator Paul Daugherty Airstream Motorhome Forums 7 06-15-2012 08:43 AM
Onan 4k 1979 Oil Filter? RichardT Mechanics Corner - Engines, Transmission & More... 2 09-28-2003 07:50 AM
Puzzling Onan Air Filter on 1995 Land Yacht scotta Airstream Motorhome Forums 1 08-20-2003 06:37 AM
Generator onan Paul Daugherty Airstream Motorhome Forums 6 11-26-2002 12:51 PM
