08-07-2019, 03:41 AM
#21
Stay Calm and Stream On
2017 25' Flying Cloud
Palm Springs
PS: MircoAir website states that at or above 4000 feet, a 2000 watt generator may not not be adequate to run AC. The North Rim Grand Canyon is about 8000 feet....
Stay Calm and Stream On!
08-07-2019, 06:20 AM
#22
2019 30' Classic
Canfield
, Ohio
The good news is at that elevation, you don't need AC!
We came out of Lake Havasu (105 degrees) and went to the grand canyon. It was 65 degrees during the day.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
08-07-2019, 03:28 PM
#23
Palm Springs
Lol Good point Turk! Right now I am Boondocking in Cedar City, Utah, 5800 ft elevation, and the AC works great with the 2200i and easy start.
08-07-2019, 04:42 PM
#24
2009 25' FB International
2018 27' Globetrotter
Tavares
Originally Posted by Ronman
Can I run my AC with easy start on my home 110v?
Most likely if you have the amperage. With Easy Start I can run my A/C plugged into a 20 amp, 110 v circuit.
08-07-2019, 07:18 PM
#25
Journeyman
2016 25' International
Amherst
, Massachusetts
Works for me. I do it all the time.
08-09-2019, 09:23 PM
#26
2016 26' Flying Cloud
Southlake
I ran the a/c on the Honda 2000 Companion today. I purchased a grounding plug from Micro Air, so I had no problems with using the Progressive Industries surge protector and, using it, was able to see the amp draw. Never got above 16A and I was able to run some lights and inverter. Overall, very pleased with all but the Texas heat. The temp in my truck was reading 107on the way to Costco.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
08-10-2019, 05:34 AM
#27
2018 30' Classic
Cumberland
, Maryland
Using gasoline I suspect?
08-10-2019, 07:58 AM
#28
Tampa
Originally Posted by Devananda-E9
Question: Site says Specs; Working voltage 80-260VAC/Test Voltage: Same.
So how dies this work on 12 volt DC?
I think the post recommended it to sniff the power cord from the generator to read the actual amps.
08-10-2019, 08:56 AM
#29
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Okay, I hooked the EMS into the generator today for the first time. Will determine my AC draw. But what hit me right upfront is that my power converter is drawing 15 amps. Batteries were down to 11.9 so I guess that is near a maximum. It sure is higher than I thought it would be. Can that even be correct? Maybe I need to put in smaller converter? It is a 45 or 55 amp converter. I expected about a 6 or 7 amp draw at full load?
08-10-2019, 11:36 AM
#30
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Dropped to 8 amps when voltage dropped to 13.6. About 15 amps when the voltage reads 14.5. Anyway this converter seems to draw a huge amount of power. I have to turn it off to run either the AC or the microwave when on generator. Converter is first thing I would check if one is short of power for the AC.
08-11-2019, 09:14 AM
#31
2011 20' Flying Cloud
Lemont
Originally Posted by Bgibbs
I should be able to leave one of my Honda 2000 generators at home now.
Eeeehhhh... not so fast. You'll be up in the mountains where the air is thinner. One Honda 2000 will definitely work at sea level, but may not at altitude. It's best not to strain one generator when you already have two.
Plus, with both you'll be able to run the AC along with the refrigerator and charge batteries. You'll also have a backup generator, too.
08-11-2019, 09:23 AM
#32
Lemont
Yes! ...but use a good 30A to 20A adaptor, no extension cords, and the AC should be the only thing drawing power.
Also, check to make sure nothing back in the house is drawing significant power on the circuit.
08-11-2019, 01:03 PM
#33
1998 31' Excella 1000
Simpsonville
, South Carolina
Over load condition
Originally Posted by Airhead2018
We also had Easy Starts installed at Doswell plus purchased Hutch Mountain propane regulator and a Honda EU2200i with propane conversion. Hooked up to propane and generator goes into overload after about five minutes of running one AC. Will investigate further today, need to make up something so I can measure the current. Slightly disappointed at this point.
Check and make sure your fridge is on propane, I had my 2200 converted at Doswell also and that solve my problem.
08-11-2019, 01:19 PM
#34
Simpsonville
, South Carolina
Yes you can !
I have a 120 volt ac outlet with 30 amp breaker for shore power, just like the KOA. Works great. If you have a 20 amp receptacle and a HD extension cord (10/3 w/ground) no longer than 100 ft that "might" work. Just make sure other stuff is off, water heater, fridge, converter--charger etc. It's always nice to be able to have air conditioner on when doing after long trip repairs inside.
08-11-2019, 01:52 PM
#35
Seattle
I have found for me the Honda 2200i will not run 15k AC at about 7000 feet in Santa Fe New Mexico with Refrigerator on propane and nothing else on. Same situation, the AC runs for about five minutes and then shuts compressor off. I also have Zamp 180 portable and batteries at 90% +. I did not switch off converter.
Micro-Air says ANY generator will lose about 3.5% power per 1,000 feet and about 1% for every 10*F above 60*F. I've got an EU2200i that's going to be operating at close to 4,000 feet and 95*F in a couple of weeks. Gonna be right on the edge.
08-11-2019, 01:56 PM
#36
1976 31' Excella 500
St. Augustine
Instead, try giving the Predator 3500 inverter generator from Harbor Freight a chance. It gets great reviews, some of them from other camper users. Cost is less than half of the Honda 3000i, which isn't quite larger enough to run your a/c and refrigerator at the same time. The Predator 3500 will.
I plan on getting one soon to add options when a campsite is not available or convenient. Since I'm not retired yet, our AS is used for weekend and weekly travels and also a bugout vehicle if a hurricane comes this way. I need the flexibility that a quiet, not overly expensive but powerful enough inverter generator will give me. My old 5500amp Briggs and Stratton powered generator is way too loud!
08-11-2019, 01:57 PM
#37
Seattle
Our Honda EU2200i runs the AC after installing the Micro-Air Easy Start...I mean we're getting plenty of cold air. Our EMS, however (Progressive Industries EMS-HW30C) shows voltage fluctuations of 116 to 121 and amperage fluctuations of 15-20 when the compressor kicks in. The gen noise is constant. Wonder what that's all about. All appliances OFF including converter.
08-12-2019, 08:21 AM
#38
2018 30' Classic
Cumberland
, Maryland
Frig was off.
08-13-2019, 06:16 AM
#39
Camping Dutchman
2018 33' Classic
Manchester center
, Vermont
Easy start and power management-battery charger?
I also installed my easy start. Went through the learning cycles and had it running once properly on my Honda 2000. Waterheater and fridge on gas and switch the breaker off of the converter.
But the second time ( during major rain- more resistance??) my Honda kept jumping into overload. Could it be my battery charger? How does one switch off the battery charger so you prevent charging batteries for the time being while using the AC? Or what else could be contributing to overload?
08-13-2019, 08:15 AM
#40
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I think you need to switch off the converter. It draws a huge load of power when the batteries are down a little. Find the breaker for the converter and switch it off.
