Old 04-27-2018, 09:53 AM   #1
2017 30' Flying Cloud
2015 23' Flying Cloud
Palm City , Florida
Easy Closet illumination
Just a small light, big results. Purchased puck lighting from IKEA and used in our dark closets. Results and usability is outstanding, so just throwing this out there in some pics. Lights are motion sensitive so they remain off when the door is closed and immediately turn on when you access the closet.
tmwinn1 is offline   Reply With Quote
Old 04-29-2018, 03:25 PM   #2
Forrest's Avatar
Aurora , Colorado
Images: 21
IKEA lighting hack
LED light strip, aluminum color.
I bought several of these cabinet lights about five years ago. They were listed as "Striberg" then, but the exact same light now (in appearance) is the "Norrfly" LED light strip, aluminum color. Previously, the input voltage was 12 volts. So, I used them in my RV where they have worked wonderfully connected to the 12 volt system. No power converter was needed. I recently bought two more of these for the same purpose, but then discovered that IKEA had changed the specifications to 24 volts. Why do that and eliminate an entire section of market that uses 12 volt systems? This would include off-grid use in remote cabins and tiny houses that use solar and battery banks for power. How did switching to 24 volt improve the product? It's really too bad, because the 12 volts lamps produce a really nice light and have been exceptionally reliable.
ID:	309758   Click image for larger version
Name:	Ikea LED lamp.jpg
Forrest
Out for coffee!
Forrest is offline   Reply With Quote
Old 04-29-2018, 03:51 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I use LED puck lights that run off AA batteries. They work well, easy to install with double sided foam tape and I have yet to change the batteries in almost four years.
2019 Ford Expedition Platinum
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 24 09-18-2019 08:12 AM
Unexpected Tail Light Illumination TXWind Electrical - Systems, Generators, Batteries & Solar 12 04-29-2016 07:06 AM
LED Flashlights as an Exterior Illumination Source perryg114 Lights - Interior & Exterior 8 01-29-2013 08:13 AM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
