Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 05-19-2022, 08:33 PM   #1
Tahoe Vista , California
Burned out LED step light replacement - 2010 Cloud
The LED step light on our 2010 cloud was all by useless as it was pretty much burned out. I ordered a new light and here is install process. Figured I would post some pics if anyone wanted to do them selves. Super easy.
One mistake I made was to not remove the black plug piece before I crimped the wires together. I had to un-crimp and take the black plug out as I couldn’t fit the wire crimps thru it. Moved the plug around the new wires form the light, then crimped and jammed them into the trailer.
ID:	416291   Click image for larger version
ID:	416293   Click image for larger version
Double J is offline   Reply With Quote
Old 05-19-2022, 08:36 PM   #2
And the light works!
ID:	416296   Click image for larger version
Old 05-19-2022, 11:14 PM   #3
casarodante's Avatar
2012 31' Classic
Golden Valley , Arizona
Always good when they work. Good job on the fix.
I replaced my step light about 2 years ago (https://www.casarodante.org/2020/04/21/isolation/) but I did it because I wanted something brighter than the measly little glow light.
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
My step light bulb burned out and I'd like to replace it with LED. Anyone done this? Re-Pete Lights - Interior & Exterior 10 08-08-2018 08:27 AM
Blue LED lights burned out Triumphdude General Repair Forum 1 05-26-2016 01:12 AM
Replacing burned out patio light 2007 Safari tksbaskets Lights - Interior & Exterior 12 08-26-2012 11:18 PM
Looking for LED Step Light Replacement Soyboy Lights - Interior & Exterior 6 05-05-2010 10:07 PM
Brake Lights LED Burned Out? campadk Lights - Interior & Exterior 10 06-29-2007 08:45 PM
