Old 09-02-2022, 01:41 PM   #1
2018 19' Flying Cloud
Eugene , Oregon
Slow Drip of Kitchen Sink
I have a slow drip under the kitchen sink. I tried tightening the fixtures - to no effect. It looks like the plumber's tape/sealant is coming undone. Is there a recommended plumber's tape or sealant one uses for this kind of plumbing?
Name:	Sink Pipes.jpeg
tjwoods1 is offline   Reply With Quote
Old 09-02-2022, 07:12 PM   #2
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
Not to be critical, but someone has used putty and tape where it shouldn't have been used. There should be rubber washers and plastic compression washers used. I would take it all apart and start over. Putty is used between the sink and the drain if it doesn't have a rubber gasket there. It's possible that a fitting may be cracked.
JEWare
John Ware is offline   Reply With Quote
Old 09-02-2022, 10:57 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
First question would be: Just what are we talking about? there are a *lot* of junctions under the sink. Which one of the many is leaking? If it is unclear which one, first step would be to identify the source. Fixing one when the source is someplace else is time and effort wasted.
The most likely source is the sink to drain. That is in no way to suggest this *is* the source in this case. If it is the source, then tear down / clean / new putty is the first step. Second step it to tighten things. It's an "enough but not to much" sort of process. If you redo it and get a leak either it's to tight or not tight enough. Try tighter and see if that fixes it. If it doesn't then it was to tight at the first attempt ( welcome to your training as an apprentice plumber ....).
There are a number of possibilities. Each has it's tricks and issues. Going into them all would take a bit ( even for long winded Bob ).
Old 09-03-2022, 06:23 AM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
There should be a few plastic washers along the way. These have a flat side and a tapered side. If they are installed backwards you'll get leaks. The flat side will face the spinning nut and the tapered will face the junction point.
This link has a great diagram: https://www.hometips.com/repair-fix/...rap-leaks.html
Richard
11018
richard5933 is offline   Reply With Quote
Drip, drip, drip. Or not to drip? Vitaver Plumbing - Systems & Fixtures 9 12-19-2016 08:25 PM
drip- drip-drip-drip-drip.... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-09-2009 08:32 AM
Arrggggg! Drip, Drip, Drip—Warning, plumbing questions Jim & Susan Sinks, Showers & Toilets 16 06-10-2009 09:04 PM
Drip, Drip, Drip kamadeca Fresh Water Systems 4 05-20-2008 09:22 PM
AC drip,drip,drip,drip,drip Canuks Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-02-2006 03:05 PM
