Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-05-2009, 09:50 AM   #1
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
HELP! Bath trim molding
I have attached pictures of the trim molding that was used in my 68 Trade Wind. I was careful removing most of it but several pieces were damaged before my purchase. As you can see, it consist of a bottom part that is screwed or riveted through and a top part that snaps on to cover the rivets. It is 3/4 in wide. I have looked everywhere for a similar product to replace this with and have not been able to find anything that is close. Any tips on where I can get this or any ideas on good alternative will be appreciated.
Bruce
ID:	84959   Click image for larger version
68 TWind is offline   Reply With Quote
Old 08-05-2009, 12:51 PM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I believe this question was recently asked and Inland Andy responded by saying it isn't available anymore. You'll need to convert to the trim and insert nosing found in early 1970s models (like mine).
1958 Overlander
2011 Wolf Creek 850N TC
4CU 1st VP
mello mike is offline   Reply With Quote
Old 08-05-2009, 02:26 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Bruce,
That trim was used up to at least 71 - in mine it snaps over an aluminum extrusion. We have looked everywhere - Airstream even let me go back in the warehouse and look. I've called several RV trim mfg. companies - no luck.
If you find it would you please report back where. Good luck....
Old 08-05-2009, 02:37 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Thanks Gary,
I'll let you know if I find anything. Hopefully someone will have a source.
Old 08-05-2009, 03:20 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The inside part looks a lot like "insert nosing" and the last time I checked Inland RV has it. I don't know if they have the extruded aluminum it snaps into.
Old 08-05-2009, 07:30 PM   #6
68 TWind's Avatar
1968 24' Tradewind
I tried them, no luck.
What's happened to Andy? No posts lately.
Old 08-05-2009, 07:44 PM   #7
MrsGlisten
1959 22' Caravanner
1963 24' Tradewind
Anderson , South Carolina
Andy told me he would be out for a couple of months. I have
MrsGlisten is offline   Reply With Quote
Old 08-05-2009, 07:45 PM   #8
MrsGlisten
1959 22' Caravanner
1963 24' Tradewind
I have removed the bathroom from my '67 Sovereign and I will look and see if I have any of the trim and offer it up.
Old 10-10-2017, 11:31 PM   #9
Fort Lauderdale , Florida
1970 Safari with wet bathroom
I'm also looking for the same trim. Can anyone post a link or picture of the aluminum trim with vinyl insert? My wet bathroom is tiny with tight curves. I wonder if the aluminum trim would be pliable enough.
writemate is offline   Reply With Quote
Molding Piece Popped Loose in Bath AustinAir General Interior Topics 1 01-13-2009 07:32 AM
Has anyone ever converted a regular rear bath to a wet bath? tvadman1963 Sinks, Showers & Toilets 2 12-29-2006 11:15 AM
'68 Safari Landyacht Trim/Molding alanandanne Clearcoat, Exterior Paint & Trim 2 12-05-2004 07:54 PM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
