Old 09-14-2021, 07:30 PM   #1
2020 30' Classic
Hampton , Illinois
Fix for shower door sag
Our shower door started to sag and became difficult to open without having to pull up on the whole door. This happened after only a year on our new 27FB Globetrotter, and we'd had a similar problem on a previous AS. I'd read several other posts on trying to adjust the hinge or raise the whole door but they all sounded rather difficult and after trying to remove the door, I gave up on those solutions. The shower and door frame seemed solid and still square, so I started guessing that he door itself was no longer a rectangle and was becoming a parallelogram.
I was able to still 'lift' the whole door a fraction of an inch so I found some spacers to fit under the outer edge of the door (opposite the hinge) and got the door closed after lifting it. After the next 100 mile drive (not necessarily bumpy) I found the the interference with the frame was less. On the next trip, I was able to increase the height of the spacers and got even more clearance and the door opened freely. The next trip with a slightly larger spacer seemed to have the door back to the original configuration with even clearance across the whole bottom.
It's a little bit of a hassle to remember to position the spacer before each trip, but it's been worth it for us.
ID:	404046   Click image for larger version
bimmersbeercan is offline   Reply With Quote
Old 09-15-2021, 05:46 AM   #2
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Put the spacer under the hinge, it will hold the door up better
Gary
Castaway is offline   Reply With Quote
Old 09-15-2021, 06:08 PM   #3
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Put one under each end even better yet.
sheriff1 is offline   Reply With Quote
Old 09-17-2021, 05:40 AM   #4
2020 30' Classic
Hampton , Illinois
Sag fix
At first, I couldn't get a spacer under the hinge that would lift the door high enough to avoid the clearance on the opposite side. Apparently our door had deformed enough that the side opposite the hinge was much lower.
By supporting the door with only the spacer on the opposite side during transport, then each bump in the road straightens the door out just a bit.
If I only had a spacer on the hinge side, I'm afraid the door would sag back to the problem position again.
Old 09-17-2021, 08:25 AM   #5
Paradise , Texas
The screw that runs through hinge bar at the TOP of the frame is the failure point, havent seen one not bend ,sag and tear plastic bushing up yet.
Crackerman is offline   Reply With Quote
« Help! | Top | Toilet »
Jacking ribs to fix mid trailer floor sag CA_Tallguy Ribs, Skins & Rivets 10 11-06-2013 09:12 PM
Door Sag: hinges or something else? perryg114 Doors & Locks 5 05-11-2013 04:10 AM
"rear sag" fix. '73 sov. TxBxSx Repairing/Replacing Floor &/or Frame 2 06-02-2012 11:41 AM
Help with door sag on vintage trailer yankeemomto3 Doors & Locks 7 04-19-2009 09:44 AM
Rear sag- or no rear sag? aviontt Repairing/Replacing Floor &/or Frame 14 08-27-2003 05:38 PM
