05-16-2020, 02:29 AM
#21
2014 19' International
2014 Interstate Ext. Coach
Cedar Rapids
, Iowa
Great idea! Please keep us informed as you go as to how it is working out.
05-16-2020, 06:39 AM
#22
Contributing Member
Austin (Hays County)
I took the AI out for a couple of nights. I hooked up the usual 30-amp and then plugged in a 14-awg extension cord to the added outside 20-amp input. I have installed a rotary switch that allows me to choose between using internal 30-amp power to the water heater or powering it from the added external 20-amp socket. I flipped the switch over to the 20-amp external power so that I had full 30-amp power to the microwave and AC. I did use the AC for a short time to cut down the humidity in the coach.
I found I had plenty of hot water to shower each morning and wash dishes. It takes about 20 minutes to heat the tank to the set temperature. Bosch has an ideal setting marked on the dial and that was where I had it set. Had I needed more hot water, I could have turned it up to full hot and added more cold water at the faucet. At the Bosch recommended setting, there is no danger of scalding.
I could always turn it full up and add a mixing valve, but I see no need for that.
It takes about 2 seconds to get hot water in the bathroom. The galley takes more time because of the long length of PEX to the galley.
I am completely satisfied with my new water heater.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
07-01-2020, 06:12 PM
#23
MJAI
2019 Interstate Nineteen
north Prince George
, Virginia
I have a 2020 AI 19, sad to say, I have never had any hot water at all. I'm not mechanical inclined , what should I do, besides take it back to dealership? I left the message of course no reply!
07-01-2020, 06:30 PM
#24
2012 Avenue Coach
Corpus Christi
If you get a chance to camp (hard during these times), you could ask another camper for advice (iffy in these times). Just on the off chance you're not doing something right.
Usually it is just a matter of having your battery switch on, propane tank full and switched on, then turn your hot water heater. What are your symptoms and what have you tried?
07-01-2020, 06:37 PM
#25
Contributing Member
There is a "Water Heater Propane" switch on my main touch panel. Make sure that is on.
Mine took full flow for 7 seconds to get it to light. That's why I replaced it.
John W. Irwin
WBCCI #9632
07-02-2020, 03:38 AM
#26
MJAI
north Prince George
, Virginia
I have a <fresh water tank heater> on the control panel, turn that on still no luck.
07-02-2020, 03:49 AM
#27
MJAI
north Prince George
, Virginia
For 2020 AI 19 does it use propane or electric to heat the fresh water tank?
07-02-2020, 07:00 AM
#28
MJAI
north Prince George
, Virginia
Well, the manual said the fresh water heater is just to keep the tank from freezing up! sad!
07-02-2020, 07:02 AM
#29
MJAI
north Prince George
, Virginia
I searched the manual couldn't find any chapter on how to operate the hot water heater, desperated!
07-02-2020, 02:18 PM
#30
1974 Argosy 26
Morrill
, Nebraska
That's because there is no such thing as a "hot" water heater.
If anything it is a "cold" water heater.
Why would you want to heat "hot" water?
07-04-2020, 04:06 AM
#31
MJAI
north Prince George
, Virginia
Could anyone here be so kind to help with the "cold" water heater on my2020 AI 19, I called dealership 3 times no one ever call back!
07-04-2020, 06:12 AM
#32
1974 Argosy 26
Morrill
, Nebraska
What is the brand name, model and capacity of the water heater in your coach?
07-06-2020, 02:21 PM
#33
MJAI
north Prince George
, Virginia
It's 2020 Interstate 19 sorry couldn't find any specific name and capacity.
07-06-2020, 05:53 PM
#34
1974 Argosy 26
Morrill
, Nebraska
Standard equipmemt on your Interstate 19 is a.
Truma Combi Eco Plus
12 gallon water heater.
There are trouble shooting tips and manuals on the net.
09-14-2020, 07:10 AM
#35
Prof. of Pending Projects
2018 Tommy Bahama Interstate
Orlando
This is what Airstream should use in all Interstates... the current one in the Lounge and GT sucks...
