02-28-2017, 09:52 AM
1993 34' Excella
Estancia
, New Mexico
Need this plumbing piece and info for 71
I hit a low spot and broke off the end of my discharge pipe on my 71. I have the pieces. So I am looking for a replacement or advice on gluing.
Is this PVC or ABS?
What glue will work
The part in question is the top ring in the photo just below the belly pan. The part below is a Thetford to Valterra adapter which is not in question. Photo was taken before the damage.
It is still servicable with a friction type Slinky end, But I would like to at least glue the broken pieces back.
Of course, a undamaged replacement would be the best solution, but I don't know if they are still made.
Thanks.
02-28-2017, 09:53 AM
1993 34' Excella
Estancia
, New Mexico
Photo posted upside down and reversed left to right
03-04-2017, 08:31 AM
Sun Rae
1977 Argosy 28
Lewisburg
, Tennessee
Is this PVC or ABS?
What glue will work
Thanks.
Had the same connection as yours 1977 argosy
I replaced mine with a heal 90* and did away with a valterra connection no adapter needed now and it's higher off ground than the original connections
03-04-2017, 08:34 AM
Sun Rae
1977 Argosy 28
Lewisburg
, Tennessee
Used standard glue glued the 90 to thetford black tank valve and three small screws
03-04-2017, 11:09 AM
1974 Argosy 26
Morrill
, Nebraska
Oatey makes a glue which will glue ABS to PVC. It is green in color.
03-04-2017, 11:37 AM
Sun Rae
1977 Argosy 28
Lewisburg
, Tennessee
Is this PVC or ABS?
What glue will work
Thanks.
Here are some more pictures
1993 34' Excella
Estancia
, New Mexico
Am I correct this glue will also glue ABS to ABS and PVC to PVC.
I still have not found anybody, even at Thetford, to tell me if the piece is ABS or PVC.
03-04-2017, 11:55 AM
1993 34' Excella
Estancia
, New Mexico
Originally Posted by jack9443
Thanks, It is good to know there is a plan B. If you still have them, would you want to sell me your original parts below the gate valve? The original T is still ok, but it would be good to have an extra. The parts below the T are the parts I damaged,
03-04-2017, 12:09 PM
2012 30' International
Livingston
In my plumbing days as a contractor, ABS was always black and PVC was always white.
ABS: This black pipe is most commonly used for drain, waste and vent applications (DWV). It's joined with ABS cement, which is black. PVC: PVC pipe is white, and is most commonly used for exterior applications such as sprinklers.Apr 22, 2011
03-04-2017, 12:13 PM
Livingston
The label on the can is green in color.
03-04-2017, 12:19 PM
Sun Rae
1977 Argosy 28
Lewisburg
, Tennessee
Got all parts from local plumbing supply and The2" valterra valve and 3" valterra adapter Amazon
03-04-2017, 01:03 PM
1993 34' Excella
Estancia
, New Mexico
I have heard old white pipe could also be ABS, Not sure.
03-04-2017, 09:55 PM
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
ABS can be white (or ivory) and black, I am quite sure thetford valves are ABS. Many interior parts on 70s and newer trailers are ABS plastic.
03-05-2017, 07:33 AM
Retired.
, At Large
Sherman, if you are looking for the collar with the nobs to attach the bayonet fitting, they should be still available. I seem to remember seeing them sitting on the shelf at work.
