Probably an unnecessary question with an obvious answer, but did you close the gray tank valve as soon as it hit zero or did you let it continue to drain for a while longer? Although the calibration issue is bad enough, the possibility that the tank doesn't hold the amount of water advertised is also concerning.
Mike
2020 25' Globetrotter Twin | 2017 F250 4x4 6.7 max tow Platinum
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
