Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 01-26-2020, 01:23 PM   #1
Tucson , Arizona
Black Tank Sensor Location 2015 19' International
The Seelevel black tank sensor on our 2015 19' International Serenity is showing an open circuit error - possibly a loose connector at the sensor. It sounds like an easy fix, but I am unable to find any manual showing the location of the black tank sensor and how to access it.
Suggestions?
Mike
Stringmike is offline   Reply With Quote
Old 01-30-2020, 03:50 PM   #2
Tucson , Arizona
With no responses on the forum, I tracked it down myself with the help of a borescope. The black tank is underneath the toilet and you can access one corner of it under the aluminum cover next to the toilet over the vent pipe. The Seelevel sensor is attached to the front wall of the black tank, pretty much in line with the toilet. The two wires from the sensor pad are joined with wire nuts above the tank and the wires continue into a harness.
All my wires looked secure, Although it's a bit tight to get fingers in this space. Replacement of the black tank sensor looks just possible with the removal of the toilet and its support, but again space is tight. Not an item designed for easy maintenance, I'm afraid!
Mike
Old 01-31-2020, 08:15 AM   #3
Rich W's Avatar
I'm In , Kentucky
Ours has the old Micropulse system and the sensor is on the outside of the black tank pipe near the pull lever. It's easy to get to and replace. Ours quit working and the telephone jack connector in the sensor had a corroded pin broken off. Replacement price is around $60 for the sensor. Still, just as easy to look down the toilet to see the tank level so I've not been in a hurry to replace it.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Black water Tank sensor location 2014 FC 30'? lewishw Electronics & Connectivity 0 09-05-2018 10:46 AM
New MicroPulse Sensor and re-cal... post mortem on old sensor RFP General Repair Forum 10 10-25-2017 07:29 PM
Blackwater tank sensor location (2006 midbath) Lotus54 Sprinter and B-van Forum 5 03-19-2017 06:48 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
