Several years ago, when we did our restoration, we too had a "Silicone-Happy" PO...I HATE %#$@*! silicone!
However, we found that if you spray
Permatex Gasket Remover (although it looks like the formula may have changed because mine wasn't "Low VOC") on it, it will soften it.
It was nasty stuff - a lot like the Aircraft Stripper we used to remove the clearcoat, but it worked better on silicone. Use a sharpened popsicle stick to scrape it all off, you'll probably need several passes to get it all off. Then wipe down the area with mineral spirits to remove the remaining residue. All traces of the silicone must be removed or else the new Vulkem/Parabond will not adhere It's a very laborious and thankless task...I'm sure it didn't take as long to put all the silicone on!
Permatex Gasket Remover can be found at most auto supply stores like Checker, Pep Boys, Kragen, etc.
The other thing we found that worked fairly well on removing the %#$@*! silicone is:
McKanica Silicone Caulk Remover Gel (VTS used to carry it, not now).
Neither really worked as well as I
wanted them to - they both needed multiple coats, but they eventually did the trick. The Permatex
will damage plastics & painted surfaces (even POR-15...don't ask me how I know!) so be sure parts are removed or protected.
Shari
