Originally Posted by shoot652
I had the same thing on my 97. You can tap the hole with metric size tap and maybe make that work.
Thanks, that's exactly what I'm doing, (after I found a "bottoming" tap). I went 1 size larger to a 10/32. It was still a little sloppy, thanks to the cheap pot metal the lock is made from, so so deal with that, I mixed up some "JD Weld", and filled the new threads with that, so I'll know tomorrow morning if it works.
In the meantime, I saw that "Silver Trailer Airstream" from Salt Lake City, had the lock, and the aluminum casting, for $98.00 each.....The representative was very rude, and sarcastic, I doubt very much if I'll be buying anything from them soon..
Hard to believe there is no more of that lock cylinder anywhere to be found.
Thanks for your suggestion...
Larry
