If it hasn’t done the leaking in the past, it likely isn’t correct. Can you get to the backside of this fixture via the outside or in the bath area. Check the owner manual. In the 22FB a removable panel by the main door allows access to the shower faucet. I think the 16 must have a similar access panel.
If you find a panel, you will likely find a loose connector that can be tightened. Just thinking through the problem based on your description. Since a leak like that could be leaking in the wall - make haste to repair it. Good luck.
M!ke
2019 Tiffin Wayfarer 24TW
Ham Radio Call sign K5FT
