Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 02-19-2018, 06:49 PM   #1
2017 23' International
Odor after linoleum replace on 2017 Airstream
recently had some warranty repairs done to fix a water leak under the linoleum. They had to take everything out , fix the leak and lay down new linoleum. When it was picked up there was a Foul odor that smelled really unpleasant. It was kind of subtle but you definitely notice it. Was concerned a rodent had died in the unit while it was being repaired because there was some cold weather. The tech scoped it out and found no animal related material.
took it back and they replaced the vent under the sink that could have caused a smell in the unit. supposed to pick it up in a few days and am nervous about this odor. hope maybe the vent wasn’t put back together right in the first repair.
Any other suggestions from the forum appreciated.
The older I get , the better I was.
troubadour1 is offline   Reply With Quote
Old 02-19-2018, 06:53 PM   #2
Sag Harbor , New York
Have you emptied the holding tanks? Hopefully you had proper chemicals in both tanks, in case some of the workers used the toilet etc.?
Old 02-19-2018, 06:55 PM   #3
Yes emptied and treated with chemicals. Also ran another cycle thru it of water.
Old 02-19-2018, 07:11 PM   #4
Leave a couple of windows cracked open if you can, for cross-ventilation, and see if the odor dissipates after a week or so. Some of the flooring adhesives can off-gas for a while. I would ask the dealer what adhesive they used, then do an Internet search for that product. Hopefully you will not find bad reviews about odors after installation!
If you have shore power, you might consider leaving a small electric heater on low 24/7, to accelerate the evaporation of any volatile components of the adhesive.
Then close the AS up tight, and wait a week to see if the odor returns. Animal smells would get worse of course.
Good luck!
Peter
Old 02-19-2018, 07:21 PM   #5
Will definitely do this if the odor is still there. tried your other suggestions regarding venting it out for a week. Didn’t work. Space heater idea will try also.
might add that during the disassembly that took place to replace the vinyl floor it’s quite possible some type of vent was not reinstalled so am hopeful that the vent replacement caught it.
Old 02-19-2018, 07:21 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Unless you had a custom floor you have vinyl not linoleum.
Old 02-19-2018, 07:24 PM   #7
Correct. Thansk. It’s a 2017 international signature 23 fb.
Old 02-20-2018, 04:23 PM   #8
2019 25' Flying Cloud
Sequim , Washington
We had warranty work performed within weeks after our new purchase following a 3-day shakedown cruise to prep for a 3 month trip. When I picked up the AS 3 weeks later and got it back home I was very annoyed to discover the workers had completely filled up our black tank. Since we were leaving the following day this presented a last minute unexpected problem for us then newbies. This was our first trailer and I had no idea workers would do such a discourteous thing. Now I cover the toilet with cellophane wrap and place a sign on the toilet whenever I leave it for even a few hours.
WestieHouse is offline   Reply With Quote
Old 02-20-2018, 09:02 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Activated charcoal... buy a box or 2 at Wartmart... or your favorite tropical fish store.. sprinkle all over the floor.. leave roof vents SLIGHTly open.. just not sealed..
Vacuum up the charcoal and discard in a garden.. it's natural.. don't put in sewer.
If the smell is chemical or otherwise, that has been effective for us...
Dry stuff don't usually stink... depends on the actual smell you are having, that worked for us with an electrical burn smell and other 'storage' smell things..
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-23-2018, 05:59 AM   #10
They figured it out it was the vent needed to be replaced. Smell is gone ! Yay
Old 02-25-2018, 10:17 AM   #11
Great news! Thanks for the update.
FYI another recent thread with similar issues:
http://www.airforums.com/forums/f44/...et-177843.html
FYI
Planning how to refloor a 66 Sovereign: currently, smelly carpet & pad over linoleum Becky Repairing/Replacing Floor &/or Frame 13 09-05-2005 03:34 PM
Self stick tiles or linoleum? dmadam Repairing/Replacing Floor &/or Frame 10 10-26-2004 10:07 PM
Linoleum Tile On Sale fireflyinva Floor Finishes 5 07-21-2004 06:57 PM
New Linoleum tile Bryanhu Upholstery, Blinds, Walls & Interior Finishes 6 09-29-2003 03:35 AM
source for high-end linoleum? Dave Cole Floor Finishes 3 10-02-2002 02:29 PM
