Old 10-23-2021, 10:24 AM   #1
Kansas City , Missouri
Inverter/converter Problems
I have a ‘94 Classic 36’ Airstream with a diesel pusher. Last evening after arriving at our boondocking spot all of the lights went out. When I fired up the generator the outlets wouldn’t work? So I started the motor and all the lights went back on (and fridge, etc). But turning the motor off caused everything to shut down again.
This morning was the same…until all of the sudden the lights went on again; I fired up the generator and the outlets worked…everything good and back to normal; for about 6-8 minutes. Then, everything back off.
We’re 700 miles from home and will get it looked at when we return; but just wondering in the meantime if anyone had any ideas or suggestions?
Thank you.
Danny
Danny ONeill is offline   Reply With Quote
Old 10-23-2021, 12:15 PM   #2
Half a Rivet Short
2017 30' Classic
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
There are a couple dozen things it could be .... when did you last check / replace / add fluid to the house batteries?
uncle_bob is offline   Reply With Quote
Old 10-23-2021, 01:46 PM   #3
New batteries 10 months ago.
Old 10-24-2021, 07:17 AM   #4
Half a Rivet Short
2017 30' Classic
2022 Interstate 24X
Hi
Do you have a voltage readout on the main DC bus? What does it say as all this is going on?
I would *guess* that "lights out" means zero volts ( or something really low ). If not then that's a starting point.
I would not be surprised to find something obscure like one of the thermal breakers being the culprit. It's rare that they go defective / hang up, but it does happen.
Old 10-24-2021, 07:57 AM   #5
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Loose ground connection?
Battery cable/clamp rotting? Sometimes they look good but rot from the inside.
Richard
11018
1994 Excella 25 Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8
1974 GMC 4108a - Custom Coach Land Cruiser (Sold)
richard5933 is offline   Reply With Quote
Question? Replacing factory converter & inverter with 2k watt inverter charger cptdzl Batteries, Univolts, Converters & Inverters 1 06-23-2019 07:55 AM
Changing out converter to an inverter/converter combo Aaron-Laura Electrical - Systems, Generators, Batteries & Solar 10 10-09-2017 08:18 AM
prep for my solar future: Inverter charger/inverter-converter combo wonderlust87 Electrical - Systems, Generators, Batteries & Solar 1 09-13-2017 10:50 AM
Update on Problems Problems pjzuk General Motorhome Topics 4 09-04-2007 06:02 AM
Problems Problems Problems pjzuk General Motorhome Topics 6 09-03-2007 07:25 AM
