Originally Posted by KATYBELLE
Thank you all for your responses! No I checked three different extension cords and several outlets in the kitchen and the fuses trips. When I plug in the 30amp rv plug (shore power) with nothing plugged in no drill it still trips the house GCFI. In other words, it trips just by plugging in. So do I need to replace all the outlets in the airstream? Thanks again for your help.
So let's look at this from a trouble shooting view.
Disconnect trailer from Garage GFI
Plug in drill directly to the garage GFI and use it what happens?
If ok= drill and garage plug is ok
Not ok= try drill in different GFI socket (bathroom). And repeat
I will assume it is ok:
So the gfi plug, cord and drill pass
Plug in shore power cord to G-GFI ( garage GFI plug) with nothing turned on in trailer, result?
Ok?
Now plug in a radio or night stand lamp
Still ok? Yes or no
Yes,
now plug in drill but do not turn it on, ok or not ok??
Now turn on drill...is this when it trips?
Yes... Suspect drill is internally shorted tripping GFI
No...
OR
Plug drill into G-GFI direct and try to drill, is it ok?
Now plug in 30ft extension cord (the one your using, and retest drill,
still ok?
Then try shore power cord, and re test using trailer wiring
And if it fails
Then it is the trailer causing it
Only after confirming the house circuit,
The plug, the extension cord, the drill, is ok then you can isolate the circuit on the trailer and start testing all over again IN side the trailer.
