Arvaterry
I have identical model with the same problem. I tried all the above suggestions without success, returned to dealer who could duplicate the problem but could not fix it, essentially they did not know what to do. I had to slow the fresh water fill to a trickle and it takes a long time (>40 min) to fill fresh 39 gal water tank.
I finally stuffed a rag around the fill hose in the neck of the inlet to seal the inflow. This seemed to create a water-tight seal that results in a siphon effect downstream inside the walls of the airstream. Once the siphon effect kicks-in (it takes about 10 seconds of forcing the rag from being spit back out while maintaining a seal), the remainder of the filling occurs normally without have to hold the rag in place.
My impression is the inlet filler hose inside the walls is at or near the same height as the inlet valve on the freshwater tank (probably a poor design by choice). There is no place for trapped air to escape and hence the immediate back flow of water. Hope this helps
