Old 12-15-2018, 02:47 PM   #1
1965 17' Caravel
Canton , OH
Does this added side trim indicate shell was taken off
I just purchased this 1965 Caravel 17. It is in overall good condition. Most of the interior is original. Looking at images of other 1965 Caravels I can see that some trim was added to the exterior in the center section of the sides. Sort of like an extension of the trim normally seen on the end cap areas. It also has a completely different rear bumper. The frame looks pretty solid, is rust free on the visible areas an has been repainted.
My question is: Would the odd trim have been added as part of a shell off restoration of the trailer?
ID:	329719   Click image for larger version
jwschnettl is offline   Reply With Quote
Old 12-15-2018, 06:57 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Hello from Colorado and welcome to the vintage Airstream hobby. The Caravel is a very popular vintage Airstream, congratulations on finding one. They are rather hard to come by. Yours looks to be in good condition.
The trim you show in the photos of your new trailer is not likely factory installed. Here are some pictures of 1965 Caravels and none of them have the trim like yours does.
http://vintageairstream.com/photo-ar...-caravel-17-3/
Having this trim added, and having a non stock rear bumper does not necessarily indicate a body off restoration. The seller should have had some information on the history of the trailer. People take the bodies off their Airstream usually for a total subfloor replacement and/or major frame repairs. Look for evidence buy studying the subfloor, front body mounting plate, and belly pan. You might see newer rivets, newer wood, or newer aluminum. You also would expect new plumbing and newer electrical components. That evidence might indicate a body off restoration seems to me.
I might add that the trailer ride height is indicative of worn out axle rubber. It looks like it sets pretty low. A normal guy wouldn't likely go through the effort of a body off restoration and leave an old axle under the trailer. So that is another clue you could check out.
I had a 66 Trade Wind 24' for a number of years. I did extensive renovation to the trailer, but not a body off frame. It did not, or does not have the body trim molding along either side of the trailer. It does have the molding along the front and rear end caps. The trim above the wheel wells is a "tire curtain support". It was an option where you could install sun blocks for your tires. Here is a photo of the old 66 Trade Wind showing no side moldings.
I gave thought to adding the molding along the sides of this trailer just to break up the "slab sided" look. The new body style came out in 1969 and most of those trailers have a lower molding in the area where yours is showing. I now have a 75 Overlander 27' and you can see the lower moldings go all around the trailer.
I might add that Airstream built the mid sixties trailers with the exterior skins on the sides of the trailers wrapping around all the way to the belly pan aluminum. They changed this technique sometime in the early seventies.
David
Name:	1708 Sale Rear Shade (Small).JPG
ID:	329726   Click image for larger version
Name:	1709 As found street side.jpg
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Shell off - How do I secure the shell once it's off? gronlampa Repairing/Replacing Floor &/or Frame 8 10-30-2015 12:22 PM
Propane tank switchover didn't indicate... Skater LP Gas, Piping, Tanks & Regulators 25 01-11-2012 05:41 PM
Need to be taken off of mailing list email notifications fastinjun Forum Admin, News and Member Account Info 3 06-14-2011 11:09 PM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
