Old 05-20-2019, 07:09 AM   #1
steve46's Avatar
1976 25' Tradewind
Flushing , Michigan
Bulkhead dimensions/pattern for 1976 TradeWind
I am refurbishing a 1976 25’ TradeWind and need to rebuild the interior walls/ bulkheads—specifically the ones between the galley and the bedroom, as well as the ones between the bedroom and the bathroom. I do NOT have the old walls for patterns or dimensions, however I DO have the slotted aluminum channels which do give me the contour of the wall curvature into which the to-be-built walls fit. I am reusing the overhead cabinets with the tambour doors, and the bedroom will be configured with twin beds. Would anyone be able to give me the dimensions for the walls (basically the width from the side wall of the trailer to the vertical edge of the wall I will build)—and those dimensions may be different on the curb side versus the road side. I would like to know the width of the bulkhead at a few points up from the floor and/or down from the overhead cabinet, as well as a few photos. Ideally a pattern or tracing would be preferable, but this seems unlikely to obtain—unless someone could point me in the direction of such a pattern, perhaps via a service manual. Thanks for any help you can offer.
steve46 is offline   Reply With Quote
Old 05-20-2019, 08:04 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
If the aluminum channels are not currently installed in the trailer, please be aware they may not be the exact shape you will need to pattern the curve of the walls. We found that to be true when we rebuilt our trailer. The channels "relax" when not installed. It took us a couple of tries to get the curve right when we rebuilt walls - used a piece of luaun to get the curve before we cut the expensive stuff.
I can't help with dimensions since we didn't use the original layout for our rebuild.
Kay
Old 06-01-2019, 11:11 AM   #3
steve46's Avatar
1976 25' Tradewind
Flushing , Michigan
Thanks, I appreciate the input on the channel “relaxing” when not attached to the wall —I, too have noticed that. I think I’ll be making cardboard patterns to start. Thanks.
Attaching bulkhead guy99 General Interior Topics 18 12-11-2006 04:34 PM
air conditioner bulkhead boomerick Furnaces, Heaters, Fireplaces & Air Conditioning 13 11-07-2005 09:44 PM
inner over bulkhead twoguys General Interior Topics 5 11-03-2005 05:40 AM
Interior Bulkhead RichardM General Interior Topics 0 08-14-2005 11:10 AM
Bulkhead Structural Value 69Ambassador General Interior Topics 24 03-21-2004 07:43 AM
