03-02-2021, 05:09 AM
#21
2021 16' Caravel
Towson
, Maryland
Good morning,
I would love to send a private message but unfortunately received this when I tried
“ Due to abuse by spammers, new members are not allowed to send links in their private messages until they have become trusted members.”
Thank you
03-02-2021, 05:15 AM
#22
Got the trusted member issue addressed. You are good to go with messages.
William C. Swinney
03-02-2021, 05:42 AM
#23
2021 16' Caravel
Towson
, Maryland
Sent. Thank you!!
THIS is one of the reasons we went with Airstream—- the Community!
03-04-2021, 06:34 PM
#24
2021 30' Flying Cloud
2020 25' International
minneapolis
Originally Posted by Life is a Highway
That is to bad, one of our worst nightmares a leak with a new unit. What happened to quality control and the high pressure wash station on the assembly line? A brand new factory and still pushing out product not checked out ready to camp. JC will fix it but I would request reimbursement for your travels. I would also not travel to Ohio until after April- Road SALT will rust and dissolve your new trailer
Road salt...don’t loose any sleep over that. Every trailer is manufactured in OH. Half of these units have been towed behind a pickup to its destination possibly doused with salt then washed off at its destination. I just purchased a 2021 down in southern Oklahoma where the roads were clean. There were a number of units on the lot that were still covered in muck & road salt. Just clean it off really well...you’ll be fine! Just like the other 50% who never realized their trailers were covered in salt before they even purchased.
03-04-2021, 06:41 PM
#25
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by BayouBiker
And when it is stationary use a level from where it is dripping from the interior shell to trace a path uphill, since water travels the steepest path. Then Use painters tape on the outside on anything in that uphill path that might be leaking. Use a suction cup on rivets to see if they leak if the cup does not hold that rivet leaks. Then spray water and see if you stopped the leak. If not tape off some more until it does not leak. Then take some tape back off a bit at a time to find the source. Once you find the source you can fix it permanently or keep it taped till you can get it in to repair.
Tape the awning rivet line first.
Then vents, skylight and anything else sticking up.
03-05-2021, 06:47 AM
#26
Miami Beach
Originally Posted by englishw
Picked up new 2021 - 20FB Caravel in Des Moines on Monday. Already put 2k miles on it through rain, sleet and snow but it’s leaking like crazy. There are at least 8 places all throughout where it’s leaking down walls and from ceiling and even through vent hood.
Any thoughts or suggestions?
I’d return it.
03-05-2021, 10:10 AM
#27
2019 19' Flying Cloud
Canyon Country
Try JC first as several suggested. Stay for the tour! Talk to people there and learn something. I will for sure do that when my time comes or on way to campground somewhere in Amish country. if it did not work out, then work with JC in getting a good one.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
03-06-2021, 05:47 AM
#28
2021 16' Caravel
Towson
, Maryland
I sure hope you have some answers. We are waiting for communication from our dealer as to whether they have found the leak and/or started to correct it....
03-08-2021, 02:11 PM
#29
2021 16' Caravel
Towson
, Maryland
Air conditioner leak apparently?
According to Dealer, they found a leaking gasket at the air conditioner and the indentation where it sits allowed a leak. They called Airstream headquarters and they were told to just reaseal it. I really hope this is all it was. Doing leak test now and then we will know.
Seems odd a brand new trailer would have a leaking gasket and still pass a leak test at the factory, but maybe it just barely was holding on?
I really hate this. I’m prepared for issues, allll sorts of issues, with camping, trailering etc later down the line. The whole aspect of a brand new Airstream already having a problem is depressing.
03-09-2021, 09:41 AM
#30
Miami Beach
Sorry to hear your struggle, just confirms my decision to not by a new Airstream until the day that AS has decided to bring back quality. They should regard quality as highly as does brands like Toyota or Honda.
03-09-2021, 07:43 PM
#31
2016 30' International
redondo beach
Not depressing.
They found the source of the leak which can be hard. A very good thing.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
03-10-2021, 04:43 AM
#32
2021 16' Caravel
Towson
, Maryland
We hope they found the leak! We have not heard back from them, I guess the sealant takes a few days to dry? So yes fingers crossed the leak test proves was the air conditioning gasket.
Depressing I suppose is wrong word——deflating? We were soooo excited. Now that excitment is just tempered with anxiety. But I guess that’s all part of a new adventure
03-10-2021, 04:46 AM
#33
2021 16' Caravel
Towson
, Maryland
Originally Posted by mythbuster88
Not depressing.
I do thank you for your input, if an experienced airstreamer says don’t worry about it, that helps!
Here’s hoping the leak test passed! Maybe we will know if all is okay before April and can get on the road.
Thank you!!
03-10-2021, 07:31 AM
#34
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
You should be good to go now. I would have confidence that it will not leak. An AC gasket can cause a huge leak but is also one that is easily fixable.
Roll safe!
03-10-2021, 07:53 AM
#35
2009 34' Panamerica
2005 28' Classic
Still
, in the thick of it
Thank you!!
Trust, but verify.
03-10-2021, 08:15 AM
#36
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Buy used, after depreciation and hopefully all "quality" has been addressed.
With leaks... the test at the factory is done before the interior in installed.
How about another as it leaves the building?
And another at the dealer during the PDI.
It shouldn't be hard to determine if the AS has a leak, it IS water after all.
Wet=leak.🤔
03-10-2021, 08:19 AM
#37
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Roll safe!
Yes..if the 'indentation' is no longer depressed and the gasket is installed properly...at a dealer?
03-11-2021, 05:23 AM
#38
2021 16' Caravel
Towson
, Maryland
Yeah, not so sure what the “indentation” is about..... they said “it’s around all air conditioners on airstreams”. This is our first one, so guess we have to trust our dealer is correct! So far, no word at all about whether anything worked etc.
Really glad we have this forum, it’s the only place I can actually get some information! Thank you!!
03-11-2021, 11:22 AM
#39
2021 16' Caravel
Towson
, Maryland
I have to say, I am VERY happy we have an Airstream despite issues with new Caravel. Having an Airstream means you have a very large community and a fantastic corporate headquarters behind your purchase. Airstream has responded to our issues and are following up with dealer. Everything is being taken care of correctly and documented
This is in drastic contrast to our friends who have a new trailer (not an Airstream) that has been to the dealer 3 times in the past year of ownership, most recently for over 4 months. They have no corporate backing them up, no answer from the dealer and finally had to hire and attorney.
Do NOT give up your research on Airstream and please consider it as an option. I’m confident we will be happy once we get out camper back!!
04-25-2021, 06:58 PM
#40
2021 20' Caravel
Gainesville
, Georgia
I am glad to hear that Airstream Inc. is following up. It’s my experience that everyone there really cares about the customers. I know they don’t want guy to have issues.
I have a new caravel also. Would you please give me an update as to where the leak was exactly and what caused it? Also how did the dealer remedy it?
Any more leaks since the fix?
Thank you!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Leaks, leaks, and more leaks
da_lizard |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
15 |
04-11-2016 11:36 AM |
Leaks, Leaks and more leaks
Jim in Pima |
5 |
12-12-2007 11:23 AM |
Leaks, leaks, leaks
jeffnjen30 |
8 |
08-27-2007 11:03 PM |
leaks leaks leaks
Globie64 |
10 |
12-31-2005 05:49 PM |
