Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 04-10-2021, 05:02 PM   #1
1954 22' Safari
Bellefonte , Pennsylvania
Axle for 1955 Safari
I was looking under my '55 Safari today in preparation to lift it for removal of the belly pan as part of the restoration process.
Wow does that old axle/leaf spring look old!
I once had a 54 Pontiac Chieftain with leaf springs which I had repaired and reconditioned, but that is another story...
The Safari towed like a dream when I brought her home, a 200 mile trip, so I do not think I really need to replace the axle, perhaps just buff off the crud and put a nice POR coat on.
Anyway, just in case I need to replace the Safari's axle/leaf spring assembly, what type/manufacturer axle leaf spring was originally installed on a 1955 Safari?
Here are a few pictures of the 55 Safari wheel/axle/leaf spring
Name:	axle wheel.jpg
Name:	leaf spring axle.jpg
Name:	leaf spring attachment.jpg
Name:	leaf springs.jpg
Name:	electric brake wire.jpg
fiftysafari is offline   Reply With Quote
Old 04-10-2021, 05:42 PM   #2
1966 22' Safari
Fredericksburg , Texas
May be a Henschen leaf spring. Looks just like the one I took off the 55. I’ve heard of people rebuilding them with success. They’re so solid I would think they could be refurbished. Don’t know if you’d get the height you want without going to a torsion. If you decide to rebuild, I still have the original in the barn if you need leafs. Good luck
Bubba L is online now   Reply With Quote
Old 04-10-2021, 06:59 PM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
I replaced my original axle with a dexter axle. Mainly to make sure bearings & seals were readily available. I also changed from a dropped axle to a straight axle to add clearance.
I had a local spring company (in business 100 years) rebuild and re-arched the originals. However I've come to the conclusion I need to have new springs made. The issue I'm concerned about is the increased weight from adding today's mechanicals. I haven't found a source that makes my spring dimensions/max weight rating so I'm going back to my local source, Benz Spring Company, Salem, Oregon.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 04-10-2021, 08:35 PM   #4
1954 22' Safari
I may need some parts if there is to be a leaf spring fix up. The clamps and carriage bolts and rubber bushings look corroded and dried.
I mentioned that I had a set of leaf springs redone for my long gone Pontiac Chieftain. What a car!!! The leaf springs had a material sandwiched between the metal leaf springs. Nice smooth ride. It does not look like the Airstream had such a cushy suspension.
The springs on my '55 are just metal leafs stacked together without shock absorbing material between the leafs.
I wonder if I could upgrade with sandwiched springs?
Are there parts available for leaf springs?
Old 04-10-2021, 08:37 PM   #5
dznf0g's Avatar
Oswego , Illinois
And quality spring shop can make whatever you need.
-Rich-
Old 04-10-2021, 08:47 PM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
^^ +1 to the above
Leaf springs can be made to order by dimension. If you want you can do that on line and have them delivered to your house.
I believe the brakes and suspension were made by Hadco.
Action
Old 04-11-2021, 03:07 AM   #7
Images: 59
I rebuilt the springs on my ‘59 Tradewind. Added a leaf to allow for modern mechanicals, tankage and flooring. Any good spring shop should have all the bushings and shackles and u bolts and plates.
I think the original manufacturer was Al-Ko.
Old 04-11-2021, 06:40 AM   #8
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Can those square drop axles still be found ?
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 04-11-2021, 06:43 AM   #9
dznf0g's Avatar
Oswego , Illinois
I don't know about those specifically, but my prior trailer had 4" Dexter drop axles. They were round tubes, but that really doesn't matter with new hanging hardware. I believe Dexter still makes them.
-Rich-
Old 04-11-2021, 06:49 AM   #10
dznf0g's Avatar
Oswego , Illinois
https://www.dexteraxle.com/products/...00-lb-capacity
This page lists 3, 4 and 6" drop spindles available.
-Rich-
Old 04-11-2021, 08:06 PM   #11
2012 23' FB International
Woodstock , Ontario
The rubber between the leafs is to reduce friction between leafs rubbing as they move. That saves the wear on the spring and provides smoother spring action
As others point out a good spring shop can make brand new springs or source new parts
JCW
JCWDCW is offline   Reply With Quote
1955 #0 7108 25' Tandem Axle Airstream Travel Camper Trailer VTG Restore Project eBay Watch Airstreams on eBay 0 03-16-2012 02:20 PM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
Axle on 1955 single axle models? glacierrunne Axles 7 02-12-2010 02:38 PM
1955 Safari Axle measurement toastie Axles 0 08-09-2008 01:29 PM
Looking at a 1955 22' Safari toastie Waste Systems, Tanks & Totes 3 11-21-2007 03:28 PM
