Greetings RMax!
Welcome to the Forums and the world of Vintage Airstream ownership!
Originally Posted by RMax
I am about to start on a restoration project on a 72 31' Land Yacht Sovereign. The twist on this project is we are going to add the Eddie Bauer hatch in the rear to make a toy hauler/camper. any ideas and input on this would be great. I have aircraft experience on sheet metal and rivets.
While what you propose is certainly possible, you are looking at substantially more work than just body work particularly depending upon how much the toys you expect to carry may weigh. In the early 1970s, Airstreams were being built with great attention to weight as most owners towed with the full-size family sedan, and this meant that the frames were not nearly as heavily constructed as those that would appear in the 1980s and beyond. The designed payload capacity of the 1970s coaches also was often less than comparable later coaches. There will also be one body related consideration and that will be that you will likely need to re-engineer the rear attachment point for the body that already has a reputation for being the source of problems with rear end separation.
I don't want to be a "downer" in regard to your proposed project, but do want to encourage you to do your homework on frame and running gear related issues before diving into this project.
Good luck with your investigation!
Kevin
