05-08-2021, 10:42 AM
#21
2018 30' Classic
Traverse City
, Michigan
Good information from everyone. Thank you and happy, safe travels.
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
05-08-2021, 12:49 PM
#22
2020 27' Globetrotter
Dacula
, Georgia
Originally Posted by GCinSC2
I didn't see this mentioned but tires have a date code molded into the sidewall.
Example 1017 Oct 2017
The code is week and year. The above is the 10th week of 2017.
05-08-2021, 05:37 PM
#23
2007 30' Classic S/O
Somewhere
, South Carolina
Need advice on when to shop for tires.
Date code interpretation corrected in post 11 by superchop.
05-09-2021, 09:24 AM
#24
Clovis
Good advice but to clarify, the first 2 digits of the date code is the week they made, not the month. In your example, 1017 would be the 10th week of 2017.
05-09-2021, 09:32 AM
#25
Somewhere
, South Carolina
Third correction to my error.
05-09-2021, 10:08 AM
#26
2018 30' Classic
Lake Charles
, SW Louisiana
We changed all five of our Michelin LTZ 225/75R16s DOT 4917 on our 18 Classic this past Feb. $1,078 c/o Tire Rack for 5 new Agilis Cross Climates which replaced the former LT tire.
As others have stated, it is neither the tread wear or any other form of appearance that matters, it is the AGE and wherein the rule of thumb is to change between every ~3-6 years.
To many including us, running on aged tires it's just not worth the risk and is a relatively low maintenance cost to replace such which spread over time & use buys piece of mind on the road.
Also wise to purchase road hazard as the majority of RV tire damage (particularly with towable trailers) happens in the form of sidewall damage from curbs and other obstructions.
"Finding the Roads that Await Us!"
Rick & Lydia Williams
05-09-2021, 02:16 PM
#27
Moderator dude
1966 26' Overlander
Phoenix
In other damage that is less in control by the driver.
A common tire to get damaged from road hazards is the right rear tire. Debris is usually closest to the curb. The RF tire kicks up the debris and the RR tire takes the debris.
To further the chain of destruction, what the RR tire throws back, the travel trailer takes.
Action
05-09-2021, 10:11 PM
#28
2017 25' International
West Lake Hills
Just buy the new tires. It’s not a difficult decision. You have a trailer worth how many tens of thousands and you’re worrying about a thousand dollars worth of tires that may avoid a blowout that totals your trailer. Find something harder to worry about.
